As per title just bought an S3 for the other arf on driving it back she mentioned that the speedo reading was diff from the tacho reading, ie she was doing 70mph and the tacho was showing 2 and arf thou revs when my car at the same speed was showing 3 thou revs would the fact that her car has 18" wheels on it instead of the normal 17" make a diffrence to the readings.
Speedo/Tacho Reading
Different size wheels wont make your Tacho and Speedo read any differently from each other. The speed comes from a gearbox sensor and tacho from sensors on the engine. Both are firmly linked through the clutch.
If you change the size of the wheels then your speedo will become inaccurate. And your actual GPS speed relative to your gauges (gearbox speed) will change but the tach and speedo should stay the same relative to each other...
As mentioned above, do the cars have the same gearbox code? it is possible that your top gear ratio is different!!Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
"Difficult is worth doing"Comment
2500 in 6th at 70 does seem a little low.more like 3000 i would think.
i guess you need to find out your gear box code and ratios.
however if it works why worry?Comment
