bbs rims
  • chiefmechanic
    • Mar 2008
    • 198
    bbs rims
    I have got a set of bbs three piece split rims to fit to my car. The rims are not build up yet. Do i just put some silicone between the rim parts and tighten up the bolts or is there some other process. I do not have any gaskets or special sealant.
    Brian
    I think you will need the BBS seals for them mate
    What rims have you got?
    • jsws3
      • Apr 2012
      • 1174
      Rtv Silicone is your friend as used buy bbs
      Only a small amount all the way round the wheel will do .
      • K Simmonds
        • Dec 2007
        • 7637
        I've built up a couple of sets of BBS split rims, Two and Three piece. I used standard silicon sealant on them with no problems, just make sure you get the mating surfaces spotless and use plenty of sealant, though equally don't go mental with it. Also wait for the sealant to dry completely before trying to remove any excess from the face of wheel, much easier to carefully peel off a few little bits than spread it everywhere.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • jsws3
          • Apr 2012
          • 1174
          Anything you need mike can supply .
          • chiefmechanic
            • Mar 2008
            • 198
            Bbs rims
            Thanks for the information. Very helpful. I have 10x15 Bbs rm rims.
