Staggered Tyres
  • Rusty
    • 18953
    Staggered Tyres
    I was recently sizing some tyres for a friend's Porsche and got to thinking about staggered wheels on the S2.
    Using 17" wheels as an example, I started to look into the diameter of the available, suitable sizes:
    205/50R17 - 636.8mm
    215/45R17 - 625.3mm
    225/45R17 - 634.3mm
    235/45R17 - 643.3mm
    235/40R17 - 619.8mm
    245/40R17 - 627.8mm
    Ideally, I wanted less than a 1% difference in diameter, to keep the centre diff on the straight and narrow...
    The two tyre sets that look the closest are:
    Option 1
    F -225/45R17
    R -205/50R17
    (636.8-634.4)634.3*100 ~ 0.4% difference
    Option 2
    F - 245/40R17
    R - 215/45R17
    (637.8-625.3)/625.3*100 ~ 0.4% difference
    Option 1 is a safer bet, as it offers more clearance up front with a ET35 wheel and also uses more commonly available tyre sizes, as 225/45R17 are fitted to nearly everything and 205/50R17 are standard fit on Ford Mondeos etc. A 7J wheel could be used at the back to save some weight, with a 7.5J or 8J up front, or 7.5J all round.
    Option 2 is a more aggressive setup with the possible need for spacers up front and rarer tyre sizes. Wheel sizes would need to be 7.5J or 8J all round, or even 8.5J up front, 7J rear...
    7J rears would need a spacer to make it not look too narrow, perhaps something in th the 15-20mm region on a 205 and 10-15mm region for the 215.
    255/35 18 and 235/40 18 are also doable
    • Rusty
      • 18953
      Holy front steering arm clearance Batman!
        Its OK, I test fitted it last week
        You minimum 8.5J ET32 and might need the arches massaged slightly if you are running low ride height
        • Rusty
          • 18953
          Looking at the numbers, 225/40R18 are a better match to 255/35R18
          215/40R18 - 629.2mm
          225/40R18 - 637.2mm
          235/40R18 - 645.2mm
          235/35R18 - 621.7mm
          245/35R18 - 628.7mm
          255/35R18 - 635.7mm
          F - 255/35R18
          R - 225/45R18
          (637.2-635.&)/637.2*100 ~ 0.2% error
          With
          F - 255/35R18
          R - 235/40R18
          (645.2-635.7)/635.7*100 ~ 1.5% error
          The closest matching option is
          F - 245/35R18
          R - 215/40R18
          (629.2-628.7)/629.2*100 ~ 0.1% error
          • Rusty
            • 18953
            To complete things, for 16" wheels
            F - 225/50R16
            R - 205/55R16
            0.1% error
            F - 235/50R16
            R - 215/55R16
            0.2% error
            • driftin jo
              • Sep 2007
              • 2222
              You can gain a bit of clearance on the front steering arm by grinding a flat on the
              rounded end , weld it up along the ground flat as it is two pieces of sheet that forms it.
              I did this a few years ago on my old 90q, worked a treat.
              • Rusty
                • 18953
                One for the more confident among us there but a good way of sorting the main issue with wider tyres.
                • Sonic
                  • Jul 2006
                  • 5514
                  This is perhaps a little OT but seemed like the right place to ask!
                  Given i have 3 heavily worn 225/40/18 R888's after the one that destroyed itself at Silverstone, would it be a problem to replace it with an also heavily used 235/40/18 R888's which i've been given by a friend?
                  I figure it has to be better than running around on 3x R888 and 1x normal road tyre and probably not much worse than replacing it with a new R888 given the tread depth difference between the new and old anyway.
                  I have a new set of 595 RSR's to fit but given the R888's do have some life left it would be good to keep them if possible, or is it a BAD idea to try and run 3x 225 and 1x 235, especially on track?
                  S2Forum.com Administrator
                  • Fat Audi 80
                    • 10547
                    Gut feel says bad idea. I can't imagine it is a good idea to mix sizes across an axle either...
                    The Perfectionist
                    • rynaqui
                      • Mar 2012
                      • 2752
                      • Country: Malta
                      Bad idea
                      1996 S2 ABY Silver
                        +1. Flog the part worns on ebay and ft the new-uns. Mismatching an axle pair is not road legal anyway AFAIK its an MOT failure. Tyres aren't something to compromise on IMHO.
                        • andy10v
                          • 5996
                          Bad idea.
                          Different front to rear grip is fine, side to side is not (unless its Nascar)
                          Sold ABY-stock
                          • Henkjan
                            • 1705
                            the MTM RSR had 265/35 17 on the front, and 235/45 17 at the rear
                            • Sonic
                              • Jul 2006
                              • 5514
                              Its a shame i didn't get both 235/40 tyres then as it sounds like that would have been an option, whereas 3x 225/40 and 1x 235/40 isn't. I checked the MOT Alex and you're right across mis-matching tyres across the same axle.
                              I think i'll just ebay then as you say.
                              Now the same scenario but in reverse - my spare is a 225/40/18. I'll be fitting a full set of 235/40/18, is it going to be safe to run the 1 225/40 to get me back from Belgium or is that pushing the limits of limping home?
                              I'm not fussed about MOT etc, but wondered if the rolling radius was similar enough to not cause a problem with the car. No point in taking the spare if it is!
