rolling arches....tell me more
  • s2driveruk
    • 12696
    HI,
    Due to a change in tyres, they have a much more square profile than the outgoing set and as a result on some dips in the road there is a slight scrubbing.
    Whats involved in rolling the arches to avoid what i believe is a slight scrub on the inside of the arch where the arch liner slots in?
    Thanks,
    David
    1992 3b S2 Coupe
  • afterburner
    • Mar 2012
    • 246
    • Country: Bulgaria
    And after rolling how does the liner slot in? I've always wondered...
    • Christophski
      • 3632
      Well if you are doing it the proper way you dont want to know the way im about to tell you...
      Get a piece of scaffolding pipe or something that fits int he gap between tyre and arch (Scaffolding works well on a mk1 golf)
      place one end at the bottom of the arch on the tyre at an angle towards the ground and then roll it around the arch to the other end, and then back again and then backwards and forwards a fwe more times each time leaning more downwards on the end of pipe sticking out of the arch. This will "Pull" and "roll" the arch outwards. To finish it off get a hammer and block or dolly to properly flatten the inside lip of the arch....
      Only do the rolling of the pipe to the desired level as each time you flare the arch more and more.
      I have dont this to about 3 cars, all of which were Mk1 golfs (caddy, cab and tin top) and it worked well on all of them apart from when it found some rot and it blew the bottom of the arch out completely leaving a nice big hole.
      Good luck....
      • Christophski
        • 3632
        Afterburner, if you leave a bit of a lip the arch liner will still fit but usually this is what catches so just do away with the liner.
        • s2driveruk
          • 12696
          leaves the oil cooler open to a stone strike i guess and lower portion of the rad too...
          1992 3b S2 Coupe
          • RowanH
            • Aug 2012
            • 76
            there are places you can rent them from, some body shops may have them for rent or do it for a price, they are basically a 20mm wheel spacer with a car hand wound jack welded to it with a solid plastic roller on the end. you wind the jack out to the arch, fit it to the hub and roll from side to side. keep winding it in stages till its rolled completely
            Looking to buy my first s2!
            • s2driveruk
              • 12696
              interesting - thanks for that. Is there any issues/precautions on the age of paint to avoid it flaking, cracking/crazing etc?
              1992 3b S2 Coupe
              • A1QSHIP
                • Aug 2004
                • 975
                Use a heat gun to warm up the paint before rolling will help to prevent cracking.
                Linky to a good "how to" video.
                "Nulla tenaci invia est via"
                • RowanH
                  • Aug 2012
                  • 76
                  with the techniques explained above using a poll or baseball bat which is a popular one ive heard many stories where they can crack your paint. obviously if there is any filler in the arch its likely to come away from the metal.
                  not worth the bodge in the first place in that case.
                  the roller seems to be a more professional way as that is just a diy made roller, the same as they would use in a body shop. probably worth contacting a body specialist to see.
                  the only things i have heard is heating the arch up with a hair dryer or simular, nothing that would blister the paint but just enough to make it less brittle. and the slower you work and less force you push in one go, the more likely you would get a good result with no problems to the paint.
                  • GT500
                    • Jun 2006
                    • 2181
                    The rollers are rubbish! Your arch isn't a uniform curve so the roller has to be adjusted as you go around. Don't bother. I didn't beleive how rubbish a job they do until i tried.
                    Warm the paint and do it with a bat or 3x2.
                    Rob..
                    87 UR 20v ABY
                    97 S6 Avant
                    • varia
                      • 821
                      • Current: United States
                      looking to rent or have my fender's rolled in chatsworth or S.F.v area.
                      This dude (eurocabi) did many cars i know, seen.
                      Excellent dude, quality job. Patient is the key as i heard.
                      Check the pictures
                      • RowanH
                        • Aug 2012
                        • 76
                        although yes the arch is not simply round i believe just winding it in slowly and rolling from side to side will still do the trick, you only really need to roll the top part of the arch, not the bits towards the lower front and rear section of it, unless you Tyre fitment is extreme.
                        • re2500
                          • May 2007
                          • 2185
                          Yeah the arch isnt a uniform curve but your wheels are! So using the roller will roll the arch where it NEEDS to be rolled in order to prevent scrubbing. For best results i find when using a roller (ive only done it once and borrowed a friends) is to lower the car onto an axle stand anblock of wood under the lower ball joint/wishbone. It basically puts the hub centre closer to where it would be when the car is on its wheels.
                          "Difficult is worth doing"
                          • A1QSHIP
                            • Aug 2004
                            • 975
                            Good Tip
                            Chris
                            • vonbeck
                              • 2455
                              Frosts were selling a set of rollers for £60 the other week I seem to remember
                              ABY Cricket Green Pearl Coupe, blk leather
                              THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
