235 Front 225 Rear or the other way round?
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Just fitted new tyres and rims to my S2, 235 front, 225 rear, handles amazingly well compared to before inline with a stiffer rear ARB. Now one of my mechanics has questioned what I have done and suggested I put the wider tyres at the back, so has my father saying it looked bloody awfull as it is
    Isn't the whole point of wider front to reduce understeer since our cars suffer from a slightly heavier front? Coupled with an RS2 FARB I should be receiving from Rusty Nut on here soon, this should be a perfect balance in my eyes, the FARB being the only missing link left.
    So what do you guys on here think? Wider front or wider rear and what would be the effects or advantages?
    1996 S2 ABY Silver
  • GazzaG60
    • 4133
    I feel it depends on a number of factors but in general the car turns better on smaller lighter wheels but grips better on more rubber.
    whats does a heat gun say about tire temps
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      I've gone for 17" Porsche Sport Classic wheels. Compared to the previous setup of 215 front 225 rear with 18" heavy 3 piece wheels, there's a huge difference in overall feel, smoothness, grip, turn in and response on the road. I was just curious if there is any benefit of a wider rear taking into account I'll be stiffening up the front very soon with an RS2 FARB.
      If MTM did it that way, shouldn't we as well
      What's the weight balance on an S2? 60-65 front to 40-35 rear?
      1996 S2 ABY Silver
        Ryan be careful of the change in rolling radius of the tyre - the front and rear much be IIRC within 2% of each other to avoid overheating the centre diff and damaging the gearbox.
        Have a look at Rusty's thread:
        I guess you are using staggered tyres to try to reduce understeer and make the grip balance more neutral?
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          I've heard this is a pretty neutral setup of tyres front to rear. Right now it's slightly oversteering at points but since I've prepared for an RS2 FARB, setup should become pretty neutral.
          I'm running 235/45/17 front and 225/45/17 rear
          235/45/17
          Radius: 317.2mm
          Diameter: 634.3mm
          225/45/17
          Radius: 321.6mm
          Diamater: 643.3mm
          Is that much of a % difference?
          1996 S2 ABY Silver
          • Rusty
            • 18953
            Just open the excel sheet in that thread. The 2 tyre sizes you mention are not best suited.
            • Colesy
              • Feb 2009
              • 2983
              It's a 1.53% difference so should be fine, I plan to run this setup when I get round to it. It's the most sensible setup for me with 7.5" wide wheels.
              Either way I'd stick with the wider tyres on the fronts unless you want more understeer. The RS3 comes with wider tyres on the front to combat understeer so point this out to your mechanic friend if he thinks it's forum nonsense!
              • jade
                • Jan 2005
                • 1811
                I run wider tyres up front, car handles soooo... Much better with this set up
                RS 2 580HP
                • rynaqui
                  • Mar 2012
                  • 2752
                  • Country: Malta
                  Cheers everone! Really it's old fashioned people that think this way
                  1996 S2 ABY Silver
                  • merlin's S4
                    • Jan 2005
                    • 1539
                    I used to run 255 on the front of my S4 and 225 on the rear. It made a heck of a difference to the handling and all but eliminated the understeer.
                    However, as others have suggested I would think that with 225 and 235 there is probably a bit too much of a difference in the rolling radius between front and rear.
                    • simon20vq
                      • Dec 2010
                      • 1379
                      I think it was ABT that ran an s2 with this sort of set up i.e. wider tyres at the front. It gave better straight line balance at high speeds from memory. Interested to know how you get on over the next few months.
                      In the UK I though there was a law that rear tyres had to be wider than fronts, don't know if that is still the case?
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        In Malta it's no real issue . Our VRT (MOT) is a joke, any piece of crap can pass
                        And this morning on the way to work, straight line acceleration and smoothness was overall unbelievably good!
                        1996 S2 ABY Silver
