Wheel bolt thread engagement
  • PeteRR
    • 1326
    I noticed today that the thread engagement of my wheel bolts seems to only be about 7-8mm, or 4 to 5 full threads.
    Seems a little short to me, or is that how it's supposed to be?
    I'm running 17" Mille Miglia Porsche Cup replicas, with the OE wheel bolts (and A8 front discs, no spacers and 996 calipers if that makes any difference).
    Any thoughts chaps?
  • Nuvo
    • Nov 2003
    • 3828
    You probably need tapered bolts rather than the radius type used on OEM wheels.
    • Rusty
      • 18953
      I run bolts that stick through the hub, more insurance
      On my OZs I run 40mm bolts.
      • K Simmonds
        • Dec 2007
        • 7637
        Four or Five threads is no where near enough, the minimum amount of load bearing thread required with an M14 wheel bolt is 8 full threads or 12 mm. Personally I'd be happier with 10 threads.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • Rusty
          • 18953
          Unfortunately many people overlook wheel bolts when changing wheels. I did this to my detriment and learned a very scary lesson. Been hot on it ever since.
          • K Simmonds
            • Dec 2007
            • 7637
            Yep, I agree mate, not many people give a thought about whether they have the correct seat bolts for aftermarket wheels and their a pretty critical component. Take it you had some work loose?
            1994 MTM RS2.
            2000 B5 TQS.
              ^^This^^. Anything less isn't enough.
              • PeteRR
                • 1326
                I'm wondering now if the Cup replicas need tapered seat bolts rather than the original radius type.
                Though, weren't these wheels made specifically for VW/Audi's, therefore I'd have thought that they had the same bolt seat profile as OE?
                Anyone else running these wheels know which bolts should be used?
                • andy10v
                  • 5996
                  If you pull a bolt out, the seat will be a conical taper, or a ball radius.
                  For length a simple check would be to stick a bolt in the wheel with the wheel off, and measure the length of the bolt that sticks out, and compare that to the depth of the hub hole.
                  Sold ABY-stock
                  • PeteRR
                    • 1326
                    Yep, good call Andy. I'll have a closer look at them tomorrow and see what's what.
                    • PeteRR
                      • 1326
                      Checked a wheel last night and it seems that they are indeed a tapered seat!
                      Backed-up by a search on here and finding Jase's old thread HERE (post #14).
                      As he did, I've now ordered a full set of M14x1.5, 60 degree tapered, 28mm long with a 17 hex.
                      That hopefully should sort it.
                      • Rusty
                        • 18953
                        That's not long enough IMO. 33 or 40mm would be better.
                        • PeteRR
                          • 1326
                          Booger! Do you think so.
                          I was thinking that maybe being the correct profile that they will sit that bit further into the seat of the wheel hole and give that extra thread engagement needed into the hub.
                          I'll check when they arrive, at least there is a slightly longer version if they're not quite right...
                          • Rusty
                            • 18953
                            The seat only makes a mm or so difference. By fitting the wrong type, you've probably crushed the alloy anyway. There's very little difference TBH, so don't worry.
                            As above, I run 40mm with no spacers and 45mm with my 5mm spacers. When I fit the 10mm, I'll be getting 50mm...
                            • PeteRR
                              • 1326
                              Cheers Andy, you can probably tell that I've only been used to O.E. up 'till now!
                              Though these were on it when I bought it (though it did have 17" and 18" O.E. Audi wheels on at various times which is probably why the bolts were overlooked).
                              At least it highlights the issue.
