Odd size tyres
  • Rikki Kitto
    • Feb 2010
    • 6276
    Odd size tyres
    OK dilemma time, I have 17" Porsche cup alloys 7J, had 245,40,17 tyres on them forever with no ill effect. Just had the baby chipped and now starting to feel a bit unsure about them so time to change.
    The rears are brand new but cheap, the fronts are barely legal so gonna change them now. Will it be OK to put 225 width on the front whilst leaving the 245 on the back for a while or should I get the credit card out and change all 4 to 225
    What tyres are people using? got a friend who can get me Continentals at cost have any of you got thoughts on these
  • BosnianS2
    • Apr 2005
    • 322
    • Home: Bosnia and Herzegovina Current: Germany
    My opinion is it would be fine to use 225 on front as long as the overall height is same as ones in rear. That means that you should not use 225 40 R 17 but more like 225 45 R 17 by my calculation.
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      I personally would change all of them to 225 but if you want to keep the 245 tyres at the rear, I would go for 225/45 as this has the closest diamater % that I can see to the 245s. There will be a 0.96% difference from front to rear, possibly a bit more since the rears will have been slightly worn out.
      Skipping out on good tyres is never recommended, it's all that's keeping you on the road afterall . I've got a set of Goodyear Eagle F1 Assym 2, great tyres but not sure what other members might recommend
      Have your tyres fitted at your home, work or a place that is convenient for you. Shop competitively priced tyres at etyres.
      1996 S2 ABY Silver
      • Rusty
        • 18953
        245 is a bit wide for 7J really. Get 4 225 Conti sport contact 3 or 5, you can't go wrong.
        • Rikki Kitto
          • Feb 2010
          • 6276
          Cheers guys looks like Conti sport going on then
          • K Simmonds
            • Dec 2007
            • 7637
            Agree with Andy, if you can get Continentals at cost then go for them.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
              225 on a 7J. Oh and I run Conti SC3s - excellent tyres. Just be careful of the sidewalls they are delicate
                Agreed re size, Conti s at cost is a bonus.
                • jade
                  • Jan 2005
                  • 1811
                  Do not put the 225 0n the front with the 245 on the back, you will not go round corners very well !
                  Put the 245 on the front 225 on the back that will work
                  I run cup 2s, 7.,5 j 245 and 225 on the back that works very well with the understeer car feels so much more drivable with this set up
                  RS 2 580HP
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Think I'm gonna put 225's allround
                    • jade
                      • Jan 2005
                      • 1811
                      Yes better option, but running slightly wider tires on the front helps a lot with understeer !
                      RS 2 580HP
                      • AQTdriver
                        • Jan 2011
                        • 750
                        I can do you some cheap michelins in 225 45 17!
                        '93 S2 Avant breaking
                        '95 S6 Avant sold
                        '83 80 Quattro SWB
                        '85 90 Quattro
                        '85 200 Quattro 10V sold
