problem with bumping the front tyres to the edge of fender
  • Tom_
    • Oct 2007
    • 1302
    • Country: Czech Republic
    Guys, i have a problem with bumping the front tyres to the edge of fender.I changed the front springs for stiffer ones but its almost the same. The wheel gap between tyre and edge of the fender,is around 10cm (i am not sure)...
    any ideas?I dont change the wheels and tyres,because the tyres are new and wheels looks good. I am thinking about new widers fenders,but i didnt find any...
    Audi Coupe Quattro 2.3 20V
  • Rikki Kitto
    • Feb 2010
    • 6276
    Not sure from the pic but the wheel looks to far forward to me, what size wheels you got?
    • Tom_
      • Oct 2007
      • 1302
      17", tyres 225/45...Tomorrow i get picture ,when u can see, how close is tyre to fender and to the edge
      • sidrick
        • Jan 2011
        • 1342
        Have you changed the balljoints recently?
        • Tom_
          • Oct 2007
          • 1302
          i changed ball joints on the steering and front top mounts
          • pasbogdan
            • Sep 2009
            • 1160
            • Country: Romania
            Same problem.With the grey car.Do not want to change wheels or brakes(on rear 10mm spacer needed to clear the porsche calipers and tire touches the fender on big bumps or tight high speed corners)
            The black car has no prob as you can see.Front rs2 brakes,rear stock,oz rims no spacers.
            Need to be careful what you like
            • Tom_
              • Oct 2007
              • 1302
              i havent spacers...i have very low offset
              • simons2
                • Mar 2010
                • 344
                Have you had the wishbones off ?
                • sidrick
                  • Jan 2011
                  • 1342
                  It definitely looks like wishbones or balljoints on the wrong side to me.
                  • simons2
                    • Mar 2010
                    • 344
                    Deffo
                    • Tom_
                      • Oct 2007
                      • 1302
                      I cant find any connection with balljoints or wishbones to dumping the tyre to fender?Can u explain to me?
                      space between tyre and fender = 5cm
                      and picture
                      • K Simmonds
                        • Dec 2007
                        • 7637
                        What offset are those wheels?
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                        • Tom_
                          • Oct 2007
                          • 1302
                          I am not sure,but around 20 or 25 i think
                          • Skull
                            • 3506
                            • Country: Slovenia
                            they want to say that maybe you fitted the left balljoint to the right side, and right side balljoint to the left side, so you wheels are too backwards, not centered to the fender.
                            p.s.: do you have ABY front hub housings? they bring the wheel a bit further out AFAIK...
                            p.p.s.: this is 7x17" ET15 with 215 45 tyres...
                            Audi Quattro WR
                            • Tom_
                              • Oct 2007
                              • 1302
                              No, i have 7A OEM hubs. So When i get picture of ball joints , do you recognize, if its right?
