I just bought an 80 dag dag estate and would like to make an s2 avant rep. How expensive would it be to convert it to 5 stud so I could fit my fave Avus rims?
4 to 5 stud conversion on 80 avant tdi
Tags: None
About 350 quid. That's doing the work yourself and shopping round for both the new and old parts.
Second hand S2 front hub's, £100.
Second hand S2 G60 brakes,s £100. May as well fit these whilst your at it.
New early B5 A4 rear discs, pads, ABS rings and bearings £100. Could possibly save quite a bit here if you go second hand and can find a complete set up in a breakers for instance.
Pair of new front wheels bearings, £50.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
Oh yes, and the drive shafts need changing, forgot about that, another 50 quid for a pair second hand.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
search my Quattro saloon thread there was some partnumbers on the CV`s i used as inners dont usually fit the poverty spec flanges1993 URS4 Avant Emerald Green 350+bhp
1991 Ford Sierra Sapphire 4x4 in Magenta
BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
I have a pair of FWD V6 Coupe drive shafts with CV joints going spare.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
Hhhmmm.
I'd have to pay someone to do the install as I don't even have a private driveway in my flat. Not really a job for doing on the side of the road
I don't think it would be financially worth it on a car that didn't cost much more than the conversion
Oh well, back to the drawing board.84 URQ 20VT
95 avant 80 TDI
87 CQComment
Does anyone know the differences in s2 coupe rear hubs and tdi front hubs? Ie offsets, cv splines and such. As they use the same size wheel bearings.Comment
Was thinking if I was to spend money on hubs, driveshafts, calipers and discs would I almost be as well to go a little further and get someone to convert it to 4wd?
Or can a tdi be converted?84 URQ 20VT
95 avant 80 TDI
87 CQComment
A tdi can be converted but it does take work, like brackets to hold the rear subframe, fuel tank from a petrol quattro etc etc,
Do a search on here and audi fans you'll find all the info you need, I'm tempted to do it myself at some point but i'd be more inclined to possibly do an engine conversion on a knackered v6, possibly an easier route? But then i may be too tempted to drop my 7A in it....Comment
Oh I'd love that.A tdi can be converted but it does take work, like brackets to hold the rear subframe, fuel tank from a petrol quattro etc etc,
It would be a brilliant winter car with good mpg.
If I could find someone to convert it to Quattro and do the hubs at the same time, I'd be very happy with that
84 URQ 20VT
95 avant 80 TDI
87 CQComment
