Another spacer question
  • huksa
    • Jan 2012
    • 121
    • Country: South Korea
    Hello, all
    I am going to need 6 mm spacers for my RS2.
    I have no luck finding off-the-shelf products. Unless I get someone to make the spacers to RS2 spec..
    Anyhow, the closest one I've found is this:
    6mm spacers with 5x130 bolt pattern. 88.9mm center bore (!)
    So.. the spacers are not hub-centric, and I have to rely on the original locking fingers on the hub to align my wheels.
    I am doubtful that the wheels would sit on the locking fingers with 6mm spacers attached. (By experience, 7mm wouldn't do..) What would be the best way to solve the problem? Do someone make 6mm spacers with three locking fingers?
  • Rusty
    • 18953
    Why 6mm? If you go a bit more then you'll get hub centric, which are much better. Maybe 10mm.
    • huksa
      • Jan 2012
      • 121
      I used to have 8.5-inch wide wheels with 52mm offset, and I thought the size is tight fit on the RS2 already. Now my new wheels have 8.5 inch with 58mm. The rear fits fine but the front interferes with the steering arm. I was looking for 6mm because I know 52mm clears, and I am concerned any less than 52mm might cause the wheel/tire stick out too much...
      Do you think 8.5 wide with 45mm fits fine inside the wheel well? (With 235/40 tires?) Then I could look for bigger spacers..
      • caterpillar
        • 2480
        www.spacer.se ;its in svedish, but google translate will help
        • Rusty
          • 18953
          Makes sense. Just wanted to know the reasons
