So I decided to build a set of BBS RS 3 piece split rims for the Ur. After a lot of measuring and researching I bought a set of bbs rs 098 wheels from Germany. These were originally fitted to Mercedes back in the late 80s early 90s.
The original spec of the wheels was 7" x 16" et35 which gave it a 1" outer lip.
The wheels were split and the barrels and centres were blasted then primed and painted in genuine bbs silver.
Centre bore of the wheels is larger for Mercedes so spigot rings are needed. Bolt holes are also a different size @12mm, these needed to be machined out to 14mm for the audi bolts.
With these wheels my measurements showed that I could squeeze a 3" out lip under the arches, just!. So I went with 3" stainless steel radinox outer lips which would take the wheel spec to 16" x 9".
