I know there have been many discussions on the right tire size of the RS2, and it looks like most will agree to the idea that the 245/40 OEM Dunlops are in fact closer to 225 in width.
Then what about the height (or the diameter) of the tire? I've been looking for answers to the question, but haven't found one so far.
If the tire width was in fact 225 mm, would the height of the sidewall be 40% of 225 (the actual width), or 40% of 245 (the stated width)?
We will have following scenarios:
1. Theoretically, if the 245/40 Dunlops were in fact 245 in width, the overall diameter of the tire would have been 628 mm. (17 inches x 25.4 mm + 2 x (40% x 245 mm))
2. If the width were 225 mm, but the height of the sidewall were 40% of 245 (the stated width), the diameter would have been same as the case N0. 1 (628 mm).
3. If the width were 225, and the height were 40% of 225 (the actual width), the diameter would have been 612 mm.
4. The actual size of the 245/40 OEM Dunlops were same as conventional 225/45 tires, the height would have been 634 mm.
I think this point is important because many people upgrade the wheels to 18 inches, and the tire choice will depend on this outcome. What is the most logically correct way to get this? I am confused.
The calculations I presented are intended as a guide, not as an absolute.
