Try Mick at Kinky Micks wheel shack or I think its Machine 7... both big in the VW world so should have some knowledge on Audis I would think. I have used both before...
Hi kit got my door seals I've got some 80mm studs coming as they don't fit not enough turns to tighten wheel nut up so There spare 60mm studs high tensile pm me mate
I bought a kit from Axis Motorsport (not around any more) in 2011 which was similar to the one linked to, a fair bit cheaper though.
It does look a good kit with the allen key heads which makes installation a bit easier and they are the correct length already so you won't have to cut them to the correct length as you would with other options.
Excellent service and they used to be cheaper than ebay, they sell them in various lengths, probably best to give them a call to see what exactly they have.
Received excellent service for replacement slim line wheel nuts as a few of mine had corroded. I notice that they also sell studs too as linked to above. The nuts I use are the first ones on this page: http://www.raceways.co.uk/Slim_Tuner...heel_bolts.htm
It's quite hard to find M14x1.5 nuts so options are limited without spending ~£5+ per nut. Porsche ones fit but have very large heads so aren't suited to all wheels. I've found these ones to be perfect for aftermarket wheels.
After a bit of research I've gone for the kit in the link in my first post, I struggled to find a comparable quality kit for less in this country. There are better deals to be had in the State's by the looks of things but by the time one factors in postage and customs fee's there's nothing to be saved. Also if you contact the seller he can do better prices than on eBay, he did me a pretty good deal on a set with both types of nut, conical and radius.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
