Wheel Spacers for skinny winter tyres S2 Avant.
  • montblancs2
    • 12
    I have just picked up a set of winter tyres on steel rims: (Vredstein SnowTrac3) 195/65 R15 91T. Usually my S2 Avant has 18" alloys with 225/40/zr18 low profiles, but living in the French Alps semi slicks are no good now the snow has arrived, fun but not for too long.
    100 Euro's got me the 4X winter tyres on steels, a price I couldn't refuse. The tyres are 195 wide, so pretty skinny compared to the usual "summer" stock but the same diameter. Tested them out and the steels fit fine over the brakes. These winter wheels were originally off a '96 A4 Estate.
    I have an image in my head of old school S1 rally Quattro's in the snow with skinny tyres lost in the arches, something similar to this russian S2 coupé look: http://img-fotki.yandex.ru/get/6105/...c4345349_L.jpg .. mine are not quite that skinny!
    For those that don't know, skinny tyres are better in snow that wide ones.
    I am wondering if this is the way to go or should I invest in some wheel spacers to keep the overall width closer to normal, I have found these on the bay - might do the trick and are not too expensive either:
    http://www.ebay.co.uk/itm/4-X-20mm-A...item5d3b089381
    Adding 20mm in theory will bring the skinny's out to where 215's would sit. What are your thoughts? Anyone have experience with this? Safety? etc....
  • elaw
    • Jun 2012
    • 62
    Two thoughts:
    1) Audi wheels are centered on the hub by the circular bit on the hub fitting into the center bore of the wheel. Those spacers don't have a projection to center the wheel, and their center bore is 76mm which is way too large to center on the Audi's hub projection which is 57mm. So not only will the wheels not have anything to properly center them, the spacer won't either. Add that to the fact the bolt holes are large and elongated and the end result is that the spacer might move which could be disastrous.
    2) As far as spacing out the wheels in general, for your steering and suspension to work best, the middle of the tread should be in the same location as middle of the tread with stock wheels/tires. So for best performance that's the measurement you should be targeting, not where the wheels are in relation to the arches.
    Be alert! America needs more lerts.
    Eric Law
    '90 80Q with AAN and Megasquirt
    '97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
    '86 4KTQ: R.I.P.
    • montblancs2
      • 12
      @elaw,
      good to know.. looks like I will have a skinny look this winter! Thanks for the advice.
