These are the alloys Im hoping to fit on the c4 A6.
And yes the cars okay, tho its got a few engine related problems that have showen up in diagnostics. So need to get them sorted.
C4 A6 AEL avant quattro: daily
TYPE-85 Coupe Quattro:clicky
2.5L GTi engineering RE2500 190hp.180lb Schrick 272 cam C A C 2.5" T304 Exhaust ITG filter
Well I've tried fsitting one to the front and its touching the steering/control arm. :-(
will a 5 mil hubcentric spacer do the trick? or should i go down to 225 tyres instead@
or maybe a 10 mil spacer? thing is i dint want to risk hitting the arches either if they come out too far.
I 'think' the alloys are 7.5 with an ET of 45?
I use these wheels on my UrS6 with 225/45 Blizzak snow tires mounted. I am using a 15mm hubcentric spacer on the front & rear. More to do with getting the wheels to fill the wheelhouse than the need for clearance.
HTH, Chris
I believe the S6 hubs have more outward offset than the A6. I did not have trouble with the sidewall of the tire hitting the steering arm but it was a close fit.
HTH, Chris
Can I ask how long your wheel bolts are with the 15mil spacers fitted?
Im guessing at least another 15mil longer bolts?
also, I think The S6 has wider front arches? will my A 6 still have enough room under its standard arches with 15mil spacers fitted?
