I've currently got 225/45r17s on the front and 235/45r17s on the rear due to slight rubbing when wider tyres are up front. Now there is a 1.42% difference in diameter between these two sizes.
Should I either go for a 225/45r17 rear to match the two up front or 215/45r17 rear with the same 1.42% difference (give or take a bit less due to the wear on the part worn 225/45r17s already on the front) to get rid of some of the understeer?
. The difference is at 1.42%, would it be worth going with slightly narrower tyres at the back?
