Wider rims (7J, 8J etc) Discussion
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    I've switched to 225/45r17s all round, the 235s I replaced have an 8.5" wide rim which are currently at the rear, the others are 7" which are at the front.
    Would it be correct to assume that having the wider rims (8.5") up front reduce understeer? Does having a wider rim with the same tyre mean that the tyre has improved contact with the ground? That's how I understand it at least
    Could be a nice discussion on tyres and rim sizes etc
    1996 S2 ABY Silver
  • Zoig
    • Sep 2008
    • 555
    http://www.s2-audi.co.uk/articles/vag_jul_95.htm
    • Rusty
      • 18953
      Not really needed if you tune the suspension properly as you can't go too wide up front what with the steering arms and all...
      OE fronts on an ABY are 16x7.5J ET37, 3B are 7J.
      Personally, 7.5J up front and 8.5J at the back to add some dish with 225 or 235 tyres all round would be best IMO.
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        Yep, already tried it and can't fit the 8.5Js up front as they would rub
        They are pretty good as they are though
        1996 S2 ABY Silver
          you need ET32 with fit 8.5s upfront
