Sneak Preview
  • martinjs
    • 3205
    They are ET48, so i have 15mm spacers with 225/40/18.
    very similar center cap, the wheel face isnt as 'flat', is dished slightly.
    I prefer the older style, but jaaps car looks really good too.
    I'll get a few pics sorted
    martin
    • jeroen
      • Aug 2004
      • 100
      #47
      ok cool!
      but do you know if jaap has sold his S2 yett?
      i know someone who might be interested. and he acclaims 420bhp (sounds a little on the high side when you take al look under the bonnet-but if i'm wrong then let me know)
        #48
        Right - much updating, some graphics added and many thanks to those he helped produce data for this page. The wheel gallery will follow...
        My brain must be fried - I just read the Offset section one more time and have confused myself again on the logic of increased -ve offset moving wheels further inboard. I'm going mad... lack of sleep maybe, but how else can 8J wheels with ET48 require hub spacers for S2 fitment. I must be right !
        Please review my wording on this - I need some sleep !
        Paul
        • 90quattrocoupe
          • Nov 2003
          • 771
          Paul
          Paul,
          Damn. That site looks great. Nice work. I wish I was that talented on a computer.
          • RS2 CQ
            • Dec 2004
            • 42
            #50
            I was wondering how Negative ET is espressed. I have never seen a ET expressed as a negative number...??
            In my case I was running 17 X 7's on my Coupe with an ET of 32 and changed to 18 X 8.5 w/ an ET of 52 and 245/35/18's. I had to increase the ET to get the wheels in the rear arches. On the front I had to have my steering arms turned in and have to use a 4mm spacer. I think I can grind some off the steering arms and not have to use any spacer in front.
            Question, you say S2's like negative ET, but in my case I am using positive ET so are US coupes diferent from Euro S2's??
            BTW...That second graphic showing ET looks great!!
            1990 RS2 Coupe
            "If you have complete control of the damn thing, you're not going fast enough!"
            • RS2 CQ
              • Dec 2004
              • 42
              #51
              Let me restate that I thought I had positive ET i.e. the face is farther out than centerline so the wheel can be further in to clear the arches... am I confused?
              1990 RS2 Coupe
                #52
                Oh balls - I think I've just spotted the fundamental error on the page. Audi wheels have POSITIVE offset. SLAP... I should have got the ruler out and measured them myself.
                Can somebody confirm my corrections and descriptions here now on the updated live page ?
                I think I've got it straight now as the words align with the diagrams, which align with talk of spaces on ET45 and larger wheel !
                My brain hurts...
                Paul
                  #53
                  You are correct - its POSITIVE offset on Audi wheels - i was off recoding the page. Check it now... I left my last post open as well while I worked on it while I thought it all through. I think I can sleep now
                  Paul
                  • RS2 CQ
                    • Dec 2004
                    • 42
                    #54
                    My brain hurts...
                    Paul
                    I went out and measured my wheels and I do have POSITIVE offset.
                    My brain hurts as well!!
                    1990 RS2 Coupe
                    • RS2 CQ
                      • Dec 2004
                      • 42
                      #55
                      Paul
                      The page looks right now!!! Great job.
                      I do not know where you are, but you probably should have been sleeping hours ago!!
                      1990 RS2 Coupe
                      • NoNonsense
                        Forum Sponsor
                        • Apr 2004
                        • 673
                        #56
                        great write-up Paul...next thing you need to update is the ABS disable switch add-on
                        Joe "NoNonsense"
                        axis motorsport
                        joe@axismotorsport.com
                          #57
                          Dudes its 2:17am - you can whistle for that tonight !
                          Zzzzz's for me
                          • Lee
                            • 1512
                            Looking good Paul. Spotted a few typos but I guess you will pick those up.
                            I actually use revolution per mile data as a selection criteria when chosing tyre combinations. All manufacturers publish this data. Tyres of the same sidewall markings can be very different in size. I use data on www.tirerack.com as they collate and publish this data. Calculating tyre sizes can be way off if you are really trying to squeeze large tyres in so I prefer to use specific numbers. I have direct experience of different tyre manufacturers interpreting the sidewall size markings differently so I do not use ((width_in_mm x sidewallratio/100 x 2) + (rimdiameter_in_inches x 25.4)) to give static diameter anymore due to this. Tyre manufacturers publish empirical data.
                            Designun Limited....
                              #59
                              Lee - thanks for the sanity check and comments. Totally agree with you about tyre sidewall markings only being an indication. The oddball tyres fitted to the RS2 in the factory are a perfect example of tyre marketeering !
                              Paul
                              • Lee
                                • 1512
                                My dad's Volvo 850R had absolutely no issues with Goodyear F1 GSD3's with 215/45R17. I told him not to use the same size tyre from another make before I checked the info but he went ahead anyway and and bought Bridgestone SO-3s in the same 'size'. They rub lots under hard cornering and I have just gone to collect him a new wheelarch liner to replace the one he buzzed a hole in!
