Hi Chaps
I'm looking at getting some 17" wheels for the sedan and have seen a set with the following spec: 8x17 et 25 with 225/45/17 rubber. The question is will they rub and will they sit too near to the arch line or worse beyond it? I don't mind a wider stance but don't want it to look silly. If I could I would try them first but they're too far away unfortunately... Is anyone with a sedan or avant running wheels to this spec (photo's?) or had them previously? I've had a read through previous threads and all I can find is a staggered set that Rob fitted to his Avant.
Russ
Russ
