Will these fit S2 coupe without rubbing and are they the correct offset and stud pattern or pcd?
Audi A8 alloys
Tags: None
You'll need longer wheel bolts as well to make up for the spacers.
Running 20mm spacers the fronts eat away at the arch liner a bit at the front bumper. As said 10mm should be enough, but clearance at rear upper arm must be very close - its close with 20mm anyway.
Best looking wheels for the S2 in my opinion.1995 Audi S2 AvantComment
What size spacer do I go with then? 10mm, 15mm or 20mm. Don't like the sound of rubbing the bumper liner! Also what size tyre would I have use? 225 45 18!Comment
I have these on my avant as you can see from my screen pic. It's lowered a bit too and is scrubbing on the rear annoyingly so they may be taken back off if I can't solve itComment
I'd go with 15mm i think thats the most common.
The rubbing is not bad, its only a very small part of the tyre which rubs when turning. 225/40/18 tyres1995 Audi S2 AvantComment
