Don't forget about your steering damper. - Maybe it's worn, and tramlining is now more noticeable due to the new setup.
I would expect a little of this from running wider tires though.
i reckon they just showed up a component which tired but isn't as 'visible' with the stock fitment.
This.
The massive sidewall on the 16s just masks other problems. The only way a larger wheel & tyre will ruin the handling is if they weigh a ton, or they alter the scrub radius significantly. In all other regards a lower profile tyre will improve the "feel" of the car and how responsive it is.
Of course remember we are talking about handling, not ride quality - that is the main reason many people like the stock wheel & tyre size.
The company who did the 4 wheel alignment spent 20 mins before checking for worn suspension components. They informed me every thing looked good and they wouldn't bother to do it if anything was worn out. The profile of the 17" tyres looked to be the same as the 16" tyre. Certainly when they stood next to each other the 17" was about 1" taller. Looking at a chart 205/55/16 should be about the same overall size as the 225/45/17. The 17" did look ridiculous big on the car, these
16" now seem tiny. Something doesn't seem right. I'll have a proper measure of them both today and try and post a photo of them together.
17x8J ET35 with 225/45R17 are pretty much the best compromise between ride, handling and looks that you can fit on an S2.
205/55R16 are very close in size but unless you're running track rubber, the soft sidewalls do mean that they take away some immediacy from the steering. They are, however, less prone to tramlining.
One option that's not been discused are 225/50R16, which are a standard BMW and Mercedes size. I ran these for years, including a trip to the Nuerburgring and they were a good compromise. Well worth a try in XL rating, to get the stiffer sidewalls. Maybe go for some semi track rubber, so that you get the stiffer sidewalls and more grip.
There's the option of running 205/50R17, which are standard fit on Modeos from the 2000s and so won't break the bank and also, as per Kit's recommmendation, 215/45R17. Both will reduce weight and tramlining a bit but really, you need to get some light rims to achieve any meaningful weight change.
Overall, I have run 205/55R16, 225/50R16 and 225/45R17 and the handling has always been average at best. The S2 has fairly primitive suspension, is heavy and thus stiffly sprung and does not have the geometry of a true sports car, so in reality, you could chase your tail on this one.
That said, any new car on big steam roller tyres will tramline like hell too, so it's also very much related to tyre width and profile...
