Wheel Wax
  • gripper
    • Jun 2008
    • 1156
    Wheel Wax
    One for the detailers amongst us !
    I have deep dished alloys on my car that are in perfect condition with a very good shine on the dish
    I wish to enhance the shine (to a certain degree) and also help keep the brake dust down. I heard mention of something called 'Wheel Wax' on one of the VW forums some years ago but cannot find anything now ?
    I don't want a cleaner, more something that goes on after its been washed just to bring the shine up better.
    The Poorboys stuff looks good but before I buy some, what do you guys use ?
    For what this cost me so far I could have bought an S2
  • Sonic
    • Jul 2006
    • 5514
    This is what you want - http://www.cleanyourcar.co.uk/sealan.../prod_589.html
    You'll only need to wax the wheels every year or so depending on how often you drive it, you can wash them with normal shampoo between this, they'll bead like the paint work, and the pot will last you for years.
    I can't recommend it highly enough.
    S2Forum.com Administrator
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      Been using Autofinesse myself, quite like their iron out cleaner and their mint wheels wheel wax.
      EDIT: As per Sonic it has to be a wheel wax to withstand the high temperatures, normal wax won't cut it. Would definitely recommend CYC, Tim was very helpful and they have a wide range of products!
      Something you might want to consider are wheel woolies, they are awesome
      http://www.cleanyourcar.co.uk/index....productId=1037
      This is what I did to get below results:
      Cleaned the wheel once with iron out and agitated using a wheel brush (hog hair), rinsed. Then added a further dose of iron out to get any spots that may have remained, added with wheel soap (Ammo Brute) and properly washed with a microfiber mitt, then rinsed again.
      After all that, dried the wheel using a Metro Vac n' blo to get most of the water out then dried with a clean microfiber towel. After the wheel was definitely dry, used Mint wheels wax with a foam applicator, applying it with moderate pressure and left it for about a half hour till it was dry.
      You can leave it for an hour but 30 minutes was enough to get it to set properly (depending on temperature, if it's cold there it might take longer). You'll know it's good to go when it's very hard to remove
      I'll let the pictures speak for themselves
      DPP_2321 by ryanaqui, on Flickr
      DPP_2325 by ryanaqui, on Flickr
      DPP_2326 by ryanaqui, on Flickr
      DPP_2327 by ryanaqui, on Flickr
      DPP_2328 by ryanaqui, on Flickr
      DPP_2329 by ryanaqui, on Flickr
      DPP_2317 by ryanaqui, on Flickr
      DPP_2319 by ryanaqui, on Flickr
      DPP_2318 by ryanaqui, on Flickr
      DPP_2312 by ryanaqui, on Flickr
      DPP_2333 by ryanaqui, on Flickr
      DPP_2336 by ryanaqui, on Flickr
      1996 S2 ABY Silver
      • Sonic
        • Jul 2006
        • 5514
        New wheels with a fresh coat of fk1000p...
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          I think I'll try that wax as it definitely looks better value than the Auto finesse being it's 4 times more product for about the same price
          How long did the wax last before needing a new coat?
          1996 S2 ABY Silver
          • Sonic
            • Jul 2006
            • 5514
            I'd say about a year, but it depends on how often you drive, where you keep it, how often you clean it etc.
            I've used other dedicated wheel sealants and found them to be very poor in comparison. The fk1000p was designed for airplane wings, so probably better for the job
            You want to use a foam applicator pad and put on a tiny amount. If you can see it you've probably applied to much, then buff it off quickly because it drys very fast. Do not whatever you do try to apply it in the sun... you'll regret that one, as i did when i thought it would be a good idea to do a whole car
            I've used about 50% of my tub and i've had it probably 5+ years. I've done maybe 10 sets of alloys + 4 complete cars.
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              You want to use a foam applicator pad and put on a tiny amount. If you can see it you've probably applied to much, then buff it off quickly because it drys very fast. Do not whatever you do try to apply it in the sun... you'll regret that one, as i did when i thought it would be a good idea to do the whole car!
              That sounds good
              I like to try different kinds of wax and normally leave it overnight and have no issues the next morning..but with one wax it took me at least an hour to really get the wax off the car, should have washed it in hindsight
              As above, anything in the sun is a no go, you want a cold surface
              1996 S2 ABY Silver
              • gripper
                • Jun 2008
                • 1156
                That looks good stuff Sonic, I think I will give it a go
                So do I just apply a little and that's it or can I buff up a bit just like a normal wax ?
                • Michael S2
                  • Dec 2011
                  • 1378
                  I use Chemical Guys Wheel Guard. Just rub some on with a cloth leave to set for 5 mins and buff off. Dirt and brake dust just rub off after using this stuff. Also leaves them nice and shiny
                  I redo it every 2-3 months. Anytime i have the wheels of the car i do 2 coats to the inside of the wheels as well, stops any stains when your cv boots leak
                  1995 Audi S2 Avant
                  • rynaqui
                    • Mar 2012
                    • 2752
                    • Country: Malta
                    This, one wheel is stained from CV grease, wasn't waxed at the time
                    1996 S2 ABY Silver
                    • Sonic
                      • Jul 2006
                      • 5514
                      Apply and buff exactly like a normal wax
