Wheel spacers
  • irish rwd
    • Feb 2013
    • 191
    Wheel spacers
    A question for anyone here use wheel spacers,
    Would you always recommend hubcentric and will longer wheel bolts be ok or will this put extra pressure on the bolts?
    I want to use 20mm spacers so any recommendations or experiences,
  • irishs2
    • Apr 2009
    • 2455
    That's the route I am taking, seems to be most common way to get different wheels on to the s2.
    Eric
    95 S2 Avant under rebuild.
    • irish rwd
      • Feb 2013
      • 191
      Are you thinking about wheel adapters irishs2?
      • irishs2
        • Apr 2009
        • 2455
        I'll be running 15mm and 20mm spacers on my avant, I got mine from bambridge here on the forum.
        Eric
        • irish rwd
          • Feb 2013
          • 191
          Oh no I taught when you said ''seems to be most common way to get different wheels on to the s2'' I taught you meant wheel adapters, sorry.
          That's my plan also, id say the extra strain on the bolts will be cancelled when they are centred up and torqued up, if you understand, the shoulder on the bolt will take it
          • mdz
            • Jun 2012
            • 775
            • Country: Latvia
            20mm is thick enough for adapters. I somehow prefer them over spacers with longer bolts.
            I'm using these:
            20mm 4x108 -> 4x108
            And set of 5x112 -> 5x112 waiting in garage.
