Help needed: Spare tyre
  • fish
    • Aug 2007
    • 2336
    • Home: United Kingdom Current: Sweden
    I am going om quite a long roadtrip next weekend (1000 miles) And am going om my 17"s instead of my 19"s problem is, they are 225/50/17 and my spare is 235/45/17... Cant get a 225/50/17 in time, so I need an alternative. What would work? It's a 2004 A6 1,8t quattro. Any help much appreciated.
    Kris
    Audi 80 Competition -94 Daily driver
    www.garaget.org/fish for more pic´s of my cars
  • AQTdriver
    • Jan 2011
    • 750
    there's only about 7mm difference in height so effectively the tread depth of a brand new tyre...
    I wouldn't worry about it...
    '93 S2 Avant breaking
    '95 S6 Avant sold
    '83 80 Quattro SWB
    '85 90 Quattro
    '85 200 Quattro 10V sold
    • fish
      • Aug 2007
      • 2336
      I am puttning a 225/45/17 om and hoping for The best. Noticed my 235 was bald, and couldnt get a 225/50 inte The sparewheel well. Must be better than no tyre at all i guess.
      • fish
        • Aug 2007
        • 2336
        225/50/17: overall diameter 656,8mm. Circumference 2063,4mm. Road surface to wheel center 328,4mm
        225/45/17: overall diameter 634,3mm. Circumference 1992,71mm. Road surface to wheel center 317,15mm
        So, what do the experts say about this? IF I am forced to use my spare, will i **** my drivetrain? And where should i put the smaller tyre? Front or back?
        Cheers,
        Kris
        • EspenW
          • Apr 2007
          • 1534
          • Country: Norway
          I haven't carried a spare tyre in any of my cars since forever.
          I carry two canisters of flat repair in addition to a bottle of NoTubes latex solution (originally made to make bike tires tubeless) and a small 12v compressor.
          Saves around 20kg and loads of space.
          1994 80E Avant
          1986 2L Golf 2 on Alcohol
          • fish
            • Aug 2007
            • 2336
            That was my plan too... But none of that will help if you really blow a tyre. Where can you get no tubes?
            • irish rwd
              • Feb 2013
              • 191
              The difference in tyre height will probably throw on the abs light, but other than that I wouldn't worry, you wont damage anything.
              If you only had a 15'' spare you will be glad of it to get you to safety.
              • EspenW
                • Apr 2007
                • 1534
                • Country: Norway
                You can get the NoTubes latex solution at most well assorted bike shops.
                Manufacturers page: http://www.notubes.com/Sealant-C14.aspx
                You could also get the stuff that Audi sells, but that is likely vastly overpriced.
                The Audi latex solution seems to hav emore density, but that could be because the bottle that I have has been opened.
                What you do is the following:
                Unscrew the valve core with a valve core tool (£3).
                Shake the bottle of latex solution before you dump it in.
                In a 2.0'' MTB bike tire, we typically use 50ml, but in order to seal up a car tire, I would just dump in maybe half the bottle, or all of it.
                Then inflate with a 12v compressor or a foot/bike pump.
                I carry two of the compressed foam type flat repair thingies too, just two have some more weapons. Still weighs nothing compared to a full size spare and gives me a bunch of extra storage space below the boot floor.
                1994 80E Avant
