Puncture repaired tyres?
  • Fat Audi 80
    • 10547
    I have just had one of my rear tyres repaired, after finding a nail AND a screw within two inches of each other in the centre of the tread.
    Has anyone else had their low profiles repaired and it is safe. A knowall in my office told me in Germany they won't repair low profile tyres as it is not safe.
    I am now worried about doing 120mph on my private test track safely.
    Can anyone offer any words or advice. The tyre place did not blink and said come back in an hour and it will be done....
    Cheers,
    Steve.
    The Perfectionist
  • karlblues2
    • Jul 2004
    • 402
    • Home: England Current: Australia
    Cheers,
    Steve.
    My understanding is that it depends where the puncture occurred. AFAIK if it's in the centre of the tread there is less flex and therefore less chance of the plug coming out through deformation of the tyre at high cornering speeds.
    Find out if the garage that repaired it, warrants its work and to what speed it recommends its repairs are safe to. The plug method must have been tested by someone to be able to be used on apssenger cars at all.
    If you are regularly doing high speed runs then I would personally swap it for the spare...but that's just me
    Cheeers
    Karl
    Oz
    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
    Audi 90 Quattro 20V 1989 7A
    Audi TTRS 2010 APR stage 2 +
    Triumph 675 Street Triple R
    • Mikes2
      • 1704
      Centre of the tread is usually ok, although some places refuse to touch Z rated tyres. Not sure what the official stance is but I've had a couple done previously and they stood up to autobahn and Nurburgring abuse.
      Mike
      http://www.s2-audi.co.uk
      • dan_b
        • Sep 2003
        • 3670
        The areas where it's absolutely verboten is any part of the sidewall or near the shoulder - if it's in roughly the middle of the tread, technically you should be ok.
        Personally I would just get a new tyre, but that's me.
          • 12431
          If its within 2" of the sidewall or in the sidewall it cannot be repaired. they put a big pad about 3 to 4" in diameter around the puncture with a dimple that goes where the hole was. Should be fine, but I wouldnt want to drive around at high speeds with it all the time.
          greg
          • Fat Audi 80
            • 10547
            That sounds like a good anwser. Logic says the a well glued and inserted plug should be at least as strong as the surrounding area and rest of the tyre. If you have "tracked" tyres with a repair then that makes me feel a little more confortable.
            I don't really want to spend £100 on a new tyre when this one is only 2 month old (about 1000 miles )...
            Cheers,
            Steve.
            The Perfectionist
            • s2driveruk
              • 12696
              how fast were you going when you got the puncture...i managed to blow a Goodyear eagle F1 last year after only about 75 miles and it was trashed completely - it happened at 80mph and the sidewalls were destroyed.
              The car tracked amazingly well even at that speed with a blow out
              1992 3b S2 Coupe
              • Fat Audi 80
                • 10547
                It was a slowey that was going down over a day or so. But as I said, a nail and a screw. So two holes repaired in my NEW Toyo tyre...
                Cheers,
                Steve
                The Perfectionist
                • Graham
                  • 1622
                  I thought plugs were illegal to use now, and that patches were the only option. Something to do with the plug extruding itself at hight speed. ??? i might be wrong though
                  • Fat Audi 80
                    • 10547
                    I don't know what they used - They fixed it!!!
                    The Perfectionist
                    • AL80
                      • 117
                      I had 3 nails in a tyre once, all in the centre of the tread, but the tyre place said they would only vulcanize a maximum of two holes in any one tyre.
                      • dan_b
                        • Sep 2003
                        • 3670
                        Which Toyos have you got? Did you manage to find some T1-S, or are you on their new one, the T1-R?
                        • audiman
                          • 4827
                          I have used repaired tyres on track and at high speeds. No problems. I did do the work myself so that way i know that it is done right.
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • jubjub
                            • Nov 2003
                            • 1242
                            I was under the impression that a tyre can be plugged up to 3 times only. The only proviso with this is that it has to be in the central part of the tread, and more importantly,they should be evenly spaced, ie, 12/4/7/o'clock.
                            Had tyres plugged on both my RS and S4. Its a real gutter getting a nail in a tyre that is a day old
                            • Baldy
                              • 469
                              • Home: Sikkim Current: British Antarctic Territory
                              I had a puncture repair on o/s/f fail on me on sunday night in the middle of a left hand bend doing about 40mph and i went veering off onto the chevrons in the middle of the road .tyre is knackered now but i was due a couple of new 1's on the front anyhow.thats the 1st repair ive ever had fail in 12 years of drivin.Had to get mi mate to bring his fullsize spare cos the space saver wont fit properly with mi front brakes and unlike u guys a fullsize wheel wont even fit in the UR quatt boot and i couldnt be bothered to start puttin rear wheel on the front and space saver on the back
                              Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                              0-60 4.9
                              1/4mile 13.5
