Hi all, just bought a 94 s2 avant, (picking it up next week, woohoo!). Will the 8x18 abt cups ive got on my urs4 fit without any work? im running 225/45x18 conti's and the s2 will be standrad ride height. Cant remember the offset off the top of my head but theyre fine one the urs4.
Cheers all
Gav
I *think* you sjhould be ok, tyre dimensions are identical to mine and I have no probs - just need to double check your offset to be sure. Normal S2 is ET37 but you can usuall make up any difference with a spacer.
Cheers all
Gav
I'm running 225/40 18's on S4 replicas with no problem. They have ET of 35.
I thought the 45 profile might throw your speedo out a bit more though http://www.miata.net/garage/tirecalc.html
HTH
Karl
Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
Audi 90 Quattro 20V 1989 7A
Audi TTRS 2010 APR stage 2 +
Triumph 675 Street Triple R
Sould be OK. I ran 235/40R18(r) and 255/35R18(f) on my Avant. The 45 ratio may put you close to the rear upright on the Avant with an 8" rim.
225/45R18 on an 7.5" rim gives 805 revs per mile, 8.9 inch wide section and an overall diameter of 25.9 inches.
235/40R18 on an 8.5" rim gives 821 revs per mile, 9.5 inch wide section and an overall diameter of 25.4 inches.
That data comes from ContiSport2 for the latter and Contisport1 for the former as they do not list your size in the newer variant. I ran these 235s front and rear at one stage and the speedo was more accurate than stock when compared to GPS. I played around with various offsets but ET35 was ok (just). I know that 225/40R18 is the largest that most recommend for the Avant but I found some larger ones that were also suitable.
Designun Limited....
cool, cheers for the info guys. Ive got 225/45x18 on there at the mo only cos the s4 came with 225/55x16 or 225/50x16 (cant remember) caopmared to the s2's 205's as o/e. If i have to change the tyres i will, just wanted to know before i put them on/
Cheers again
Gav
