245/35-18 on UrS4
  • blo ndie
    • Jan 2005
    • 6
    • Country: Denmark
    245/35-18 on UrS4
    Hey.
    anybody know if i can mount 245/35-18 tire on the rear axel of my Audi UrS4 from 1993 and 225/40-18 on the front tire??
    normal it has 225/50-16.
    It is on 18 x 8 rims
    Audi S6plus with 337 Hk and 388 Nm
  • quattroboy
    • 164
    • Home: United Kingdom
    If you are running 18" x 8J's anyway then why don't you put 255/35/18 Tyres on in each corner if you want wider rubber?
    225/50/16 = 631mm Overall Tyre Diameter
    225/40/18 = 637mm OTD
    245/35/18 = 629mm OTD
    255/35/18 = 636mm OTD
    Follow the link -
    Tyre Size Calculator - click here or call 01244 813030 for more information
    I am running 255/35/18's on Oettinger 18 x 8J Rims with ET35 on my UrS6
    HTH
    Dave
    Originally posted by blo ndie
    Hey.
    1997 S6 Avant
    • blo ndie
      • Jan 2005
      • 6
      • Country: Denmark
      Hey Dave.
      i have been told the there is an small difference on the S6 and S4 when we are talking space to the rear tyres...
      I know that S6 can run on 245 or 255, but my tire-mann says my S4 only can take 225....
      But how about different size????
      225 on the front tyres and 245 on the rear tyres??
      isen´t there a problem when we are talking quattro cars??
      • quattroboy
        • 164
        Personally I wouldn't feel comfortable running different profile tyres on different axles with anything quattro ie; 637mm with 225/40/18's and 629mm 245/35/18's because although 8mm is a small difference it "could" be enough to screw the diffs up?
        I would go with the same size rubber on each corner.
        Don't know if there is any difference re- Tyre sizes on UrS4's compared to UrS6's but you could probably find more info from the following site?
        http://forums.audiworld.com/s4s6/
        Let me know how you get on?
        Dave
        Hey Dave.
        1997 S6 Avant
        • Lee
          • 1512
          Diameter means nothing on tyre calcs. You need revolutions per mile to work out differences and to do that you need to know the tyre manufacturers....tyres deform under use and sidewall construction becomes an issue as it changes the rolling radius. Theoretical calculators are BS and not appropriate for a Torsen diff. I have seen a greater difference than the sizes you are concerned with on the SAME SIZE tyres but they had a 4% difference in roliing radius.
          I run 255/35R18(f) and 235/40R18(r) on an S2 with 8" rims and it is quite tight. This has considerably smaller arches than the URS4 so you should be ok. Same size sidewall markings can also result in up to 1" difference in the overall tyre width as it depends how the manufacturers interperate the size. Tread widths are often published in adition to section widths and this can be used to 'guesstimate' the roundness of the sidewall. Many sources also have data for corrections based on different rim widths on the same size tyre but this is unfortunately not hard data.
          Designun Limited....
          • merlin's S4
            • Jan 2005
            • 1539
            I've got 255/35/18 all round on my S4 but my RS6 replicas are 8.5j with a 30 offset! This makes for a gorgeously fat stance especially when viewed from the back and 245's would def look smart but there's no way you should run different tyres front to back! I won't even put any new tyres on without changing all four corners for the same. It's not worth risking your diff and running gear for!
            • Lee
              • 1512
              Mine are 1% different in revs per mile between front and rear axles...torsen can tolerate more than that...it is designed to. In fact it has to tolerate at least new tyres on one axle and worn on the other and IIRC it can cope with up to 15mm difference (not something I would do). I run a 80W140 gearbox oil too which helps the Torsen do its job!
              • audiman
                • 4827
                You dont have to change all 4 tyres at once!! That would be ridiculous.
                Tom C - www.rcmr.co.uk
                Audi UR Quattro
                Audi 100 C3 2.0 5 cyl 115ps
                Audi B5 RS4 645ps 911nm
                • Lee
                  • 1512
                  it sin't ridiculous if yyou are cycling the tyres front to rear to even the wear....certainly a big bill every time!
