Wheel offset help
  • irish rwd
    • Feb 2013
    • 191
    Wheel offset help
    Yesterday I got offered a set of wheels 17x8.5 et 38.
    Will these fit with out scrubbing the inner rear arch and inner front strut?
    Car is lowered 60/40mm.
    No tyres yet put plan to use 225/45's.
    The car in question is a 80 saloon 2wd.
    Thanks for any help.
    (I have done a search but nothing of these exact sizes..)
  • Skull
    • 3506
    • Country: Slovenia
    from my experience:
    that 8,5 and et38 would be perfectly aligned with the rear arch on a quattro sedan, the fwd is narrower on the back, so it would should fit no problem.
    Audi Quattro WR
      I would say you might need 3-5mm shim up front, but try first. It depends on tyre shoulder width
      • Simons
        • Jul 2007
        • 530
        • Country: Spain
        May this help you
        http://www.1010tires.com/Tools/Wheel-Offset-Calculator
        • GazzaG60
          • 4133
          depends on b3 or b4 arches
          on my s2 i run 225 45 17 on 38 and 225 40 18 on 35 - both cleared just fine.
          on the b3 the 17's fit just about a bit tight the 18's no chance.
          thats a b3 on s2 running gear though
          • irish rwd
            • Feb 2013
            • 191
            B4 arch Gazza.
            Thanks for all replies great help
