Wheel Bolts
  • Sonic
    • Jul 2006
    • 5514
    Wheel Bolts
    I just cleaned up my other set of alloys with Toyo T1R's to fit, only to find i've completely lost my set of tapered wheel bolts.
    The Speedline's i have fitted are radius, so i guess i'll be getting another set, only i can't remember what thread i should be getting.
    Can someone confirm? IIRC it's M14x1.5 30mm.
    S2Forum.com Administrator
  • Ringmaster
    • Jun 2014
    • 180
    Pretty sure they're 27mm. But wait for someone that knows for sure!!
      27 or 30, no matter. M14 x 1.5 is correct
      • Sonic
        • Jul 2006
        • 5514
        Cheers!
        Anyone have a recommended place to get them? Or a place to get tyres changed in Milton Keynes after one of the valves blew out during cleaning!? Glad that didn't happen whilst they were on the car!
        • Rusty
          • 18953
          I ran 40mm bolts on my aftermarket wheels, which gives a bit of head room for track use
          I recently went for an 80mm stud conversion with both taper and radius seat bolts. £59 all in from 'maps' on eBay. Good quality stuff but not track tested them yet.
          I have a full set of taper seat 33mm long bolts in black that are for sale
          • andy10v
            • 5996
            These ones?
            http://www.ebay.co.uk/itm/20-AUDI-CO...item4187550496
            Sold ABY-stock
            • andy10v
              • 5996
              Did you loctite the studs into the hubs?
              Sold ABY-stock
              • Rusty
                • 18953
                Yes and yes, was £59 + £10 for a set of taper nuts.
                Used a wheel bolt and but to fit them and torqued to 25Nm with threadlock and all cleaned first off with brake cleaner. Wheels have been on and off a few times with no loose studs.
                If you do go for those, make sure you get the deeper nuts and also a really deep reach socket - I got a draper alloy wheel socket and drilled the centre plastic out of it.
