Tyre size for 17" wheels?
  • John.
    • 2619
    I'm going to be getting tyres soon for a set of (ex 80 cab) Boleros which will be fitted to my B3 CQ. The Boleros are 7" by 17"........so...... Do I go for 225/45's or 205/50's
    225's seem to be cheaper but what are others running on their 17" wheels.
    Car has standard 205/60x15's at the moment.
    Cheers folks.
    John.
    Are you sure they are just 7" wide ? What ET are they ?
    I'd be thinking of 225/45/17 for various reasons.
    • _ShurikeN
      • Mar 2010
      • 733
      • Country: Russian Federation
      4x108 Boleros 8G0601025BZ17 7x17" ET37. I would prefer 225/45 but it's better to be sure of the tie-rod end clearance.
      • John.
        • 2619
        et37 I think? Will check tomorrow. Yes 7"
        • bazburn
          • Feb 2010
          • 583
          I have similar sized rim's and use 205/40/17 for that offset but would have thought a different offset would be needed for 225 tyres and then your talking arch foul....might be wrong, has been known...
          • mdz
            • Jun 2012
            • 775
            • Country: Latvia
            Apparently there's at lest two types of 4x108 Boleros, because the ones I had on my car was 8J ET35. Tyres was 205/45 but now I'm having 8J ET35 wheels with 225/45 with no clearance issues.
            • GazzaG60
              • 4133
              ok on my b3 I hjave had the bbs rs2 wheels with 225 45 17 tyres. fitted greay on s2. on the saloon very tight. offset is 35 and they stick out a bit. moving the balljoint fully into the arm helps lots.
              I got some s4 wheels on the way. will let you know if they are a waste of cash.
              • Bowie69
                • Nov 2013
                • 2681
                Boleros, ET37, 225/45/17 and no clearance issues on a '91 CQ20V
                Going back to the 205/60/15 speedlines soon, now I have a decent set, and hoping for a better ride quality after that
                • _ShurikeN
                  • Mar 2010
                  • 733
                  That's very interesting, don't you have a partnumber or they were not OEM audi? I have seen 8J only with 5x112 PCD.
                  • Rusty
                    • 18953
                    on 7J, I'd be looking at 205/50R17 as 225/45R17 is going to look a bit baloon like. 215 may also be suitable, I'd look at 45 profile to stop them looking like tractor wheels.
                      • 4754
                      John if they are genuine 80 cabriolet wheels they will be 7J X 17H2 ET37 (pt no 8GO 601 025 B) guaranteed! They originally came with 225/45/17 tyres from the factory and we have these wheels on our final edition cabriolet.
                      Will 225 tyres fit? Yes most definitely with no issues at all. Cabriolet is a B3 chassis.
                      There were 2 versions,maybe more, of these wheels in 4x 108 pcd. The 7J et 37 and the
                      8j et35 which has a much deeper rim to it and is rare!
                      Audi also did a 8j et 35 in 5 x 112 for the A4/A6 again deep dish which i sold to tonks on here. That should clear up a few not sures.
                      • mdz
                        • Jun 2012
                        • 775
                        • Country: Latvia
                        They also has 45° lip instead of 90° I've seen on other 4x108 Boleros.
                          • 4754
                          Yep MDZ thats the one and a rare wheel. I kinda wish i hadn't sold them now.
                          • K Simmonds
                            • Dec 2007
                            • 7637
                            215/45's work very nicely on a 7J 17" rim on our cars, after much experimentation it's my size of choice. 225/45's however are fine and cheaper, 205/50's would work but I'd only consider that for a winter tyre size.
                            It's worth noting that 215/45/17 is very close in rolling radius to a 205/60/15 which is a factory spec size for B3 CQ's etc.
                            1990 B3 2.0 80 quattro.
                            1992 C4 2.8 Avant quattro
                            1994 MTM RS2.
                            1998 B5 TDI quattro Sport.
                            2000 B5 TQS.
                              • 4754
                              . with kit on tyre sizes.
