views on different size tyres front and rear
  • GazzaG60
    • 4133
    guys
    the b3 saloon has narrow arches. at the rear its no issue.
    at present i got a 235 45 17 on an et47 wheel at the rear and it fits fine. at the front i know once i have the correct arms on it wont from forum experience at present it fits but its too wide. the difference a 4 pot arm makes is massive. they would take an et50 no worries. this weekend i hope to confirm the lack of space i have, ball joint effects on wheel centre n all that jaz
    if say i go 215 40 17 or 215 45 17 up front and keep the rears other than looking strange whats the views. i know the rolling radius is different.
    experience and views. especially on tyre clearance and sizes of tyre on a 17 up front. rears i can work out no issue. its only slightly lowered maybe 20-30mm.
    cheers in advance
  • andy10v
    • 5996
    As long as you keep the rolling radius/diameter the same you can run different widths. Narrower fronts will not help with understeer though
    I ran 225 fronts and 205 rears for a while. Them MTM RSR ran much wider front wheels and tyres than rear to help with front end grip.
    Sold ABY-stock
    • GazzaG60
      • 4133
      I doubt ill get much choice. im hoping that a 215 will clear. i may be able to work it out with the 235's to an extent or the 225's i also have.
      in an ideal world id be able to fit the wheels but the narrow arch im sure is gonna upset me.
      ive just been reading a few older posts and within 2% seems to be the figure for rolling radius. so 225 45 and 235 45 is fine at 1.44% 235 and 215 45's are just at at 2.x%
      if anybody has a b3 saloon let me know your experiences with tyres please.
