wheel spacers
  • Beetie
    • Oct 2003
    • 1517
    wheel spacers
    Whats the low down on how the wheel has to sit on the hub? The spacers im using at the min have no flange for the wheel to centre on and i think thats the cause of my wheel vibration at 40 to 50 mph. I presume it puts alot more stress on the wheel bolts...... Should i replace with ones that have an extended flange?
  • 90quattrocoupe
    • Nov 2003
    • 771
    I am running 8mm spacers with what H&R calls lip. Works pretty good for centering the wheels.
    • martinjs
      • 3205
      Beetie, does the wheel not locate on the hub anymore? I had about 4mm of hub to locate on when i used them with S4 wheels.
      • RoscoS2
        • Aug 2004
        • 190
        Just fitted new wheels (Alpina's) and have quite a bit of play with the hub centres, I apparently need to get some plastic 'spiggot rings' that will eliminate this play. Till then the wheels judder/vibrate at around 80mph, however tightly they are bolted on.
        Also I'm running 17's with et20 offset, I have no problems with arch clearance as my car is not lowered. It looks alot better than the standard ET, given that they stick out an extra 15mm. Is this safe or should I look at getting them machined down...?
        Rosco
        • martinjs
          • 3205
          ET20
          They must stick out quite a bit.
          Have you got any pics?
          • s2avant
            • 2426
            I offered up an ET20 RS4 rim on my avant and they stuck out miles. How wide are your 17's?
            Ben
            • RoscoS2
              • Aug 2004
              • 190
              To be honest there not that bad as you can see. Creates a nice aggresive stance, but not illegal...
              Getting the centre caps refurbished as we speak, was a bit hesitant about putting alpinas on an audi, as they are mainly bmw, but they look tough all the same, and only £255 with 6mm tyres off good old ebay.
              Rosco
              • Beetie
                • Oct 2003
                • 1517
                No doesnt touch the hub atall... I think the inside of the wheel where the hub is is shamfered
                • martinjs
                  • 3205
                  Darnit, they wont be any good then beetie.
                  Could you get away with using a thinner spacer?
                  How far off is the wheel from locating on the hub?
                  • Beetie
                    • Oct 2003
                    • 1517
                    I wouldnt really like to use a thinner spacer, as i dont like how close it still sits..... They are on anyway, well on the front, but will have to do something soon anyway....
                    • Beetie
                      • Oct 2003
                      • 1517
                      Is it possible to make 5mm spacers with a flange for the wheel to sit on or is it too smaller thickness to do it?
                      Martin, do you fancy making some with a flange for the wheels to sit on?
                      Apparantly nobody does them according to some wheel company thats quite big locally!
                      • martinjs
                        • 3205
                        Yeah could do, but you are right they are a bit thin .
                        The only way would be to have a 45deg lip which will locate in the chamfer in the wheel. But it will have to be a good fit. Too small lip and the wheel will be loose, too big and it wont sit flush against the hub.
                        can you get a pic of the back of your wheel beetie?
                        martin
                        • curlyks2
                          • 1069
                          How would something like these suit?
                          MTM make them, so they're not cheap, but you should be able to get them from any MTM reseller. Don't personally know the available size range.
                          NCT MTM or any of their resellers.
                          Ck.
                          Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                          • Beetie
                            • Oct 2003
                            • 1517
                            Yeah it needs to be something like that but it looks like the flange is smaller than the 56/7mm? that is standard on the hub.....
                            • Beetie
                              • Oct 2003
                              • 1517
                              Oh and ill try to get some pics, but it might be easier at the garage meet.....
