3B Alloys fitment over 996 4 pots?
  • gmac78
    • Oct 2009
    • 928
    • Home: Scotland
    Hi Guys,
    I've just bought a full set of 3B alloys and wondering what is needed to make them fit over my 996 calipers, part number 425/426. I am currently using the slimline bracket from Bambridge, with 314mm x 30 discs.
    I think i might require a spacer but not 100%? Haven't received the wheels as yet so unable to check.
    Can anyone shed any light on this for me, i've been reading some posts regarding fitment using the 16" Avus alloys (ABY) but haven't found someone that has used the 3B alloys.
    Any help greatly appreciated.
    Gordon
    S2s came with 2 different wheels. The early S2s, including 1990-92 coupes, and the early 93 coupes and 93 S2 avants, got a five spoke 7J x 16H2 ET37 wheel made by Ronal, code C4G, PN 895601025H. The later cars got the C5T 7.5J x 16H2, ET37, 16" Avus, PN 895601025M like the UrS6s (and some 94 UrS4s). The first photo shows the S2 five spoke C4G wheel, the second the rare S2 sedan sporting the C5T Avus wheels.
    So both S2 wheels were 16 inch and both were ET37. You might get lucky.
    Ur S-car Info 101:
    • gmac78
      • Oct 2009
      • 928
      • Home: Scotland
      Yeh the wheels i bought are the early 5 spoke type, can't wait to see what they look like sitting on H&R cup springs. I'll certainly get some pics up once i have the fitment issue sorted.
      • Mikes2
        • 1704
        based on previous experience, they won't clear the brakes.
        I had the RS2 calipers on mine and the spokes fouled
        Mike
        http://www.s2-audi.co.uk
        • mike74
          • Apr 2014
          • 615
          Stolen from S2Central's site & trimmed down a little (hope you don't mind Paul?)
          3. Porsche 996 / Audi RS2 / Audi A8 Kit
          •323 x 30 discs from the front of a 1st generation A8
          •Front calipers from a Porsche 996 - available in red, black or silver... 4-pot Brembos
          •Caliper carriers from the front of an RS2
          •Hard brake lines also from the RS2
          •Pads for the Brembo/Porsche calipers - lots of choice in roadgoing or trackday materials
          Basically it all bolts up a treat to the front of the S2 with a few minor tweaks -
          •Ensure that there are no balancing weights on the standard 16" Avus wheel which could interfere with the caliper. Note this kit does NOT work with the original 5-spoke wheels of the earliest S2s.
          Some variations on this theme have been to use the cheaper caliper carriers from a Seat Cupra R (Brembo equipped) and to reduce the disc diameter to 314mm to provide greater pad and rim clearance.
            ABY alloys fit with 314s, 3Bs require spacers but you'll want spacers on stock wheels anyway, as 205 tyres are narrow. Go 10-15mm up front and 20mm at the rear.
            323s don't fit under 16s without a bit of luck.
            • gmac78
              • Oct 2009
              • 928
              • Home: Scotland
              Thanks for the fast response guys, i was worried that after purchasing the wheels they might not fit, phew!!
              So, basically they will fit but require spacers, this is not a problem so will get some ordered. Is there any one you can recommend that sells them with the longer correct wheel bolts?
              Will any type of hub centric spacers do? From some of the pics that i've seen, the diameter of the wheel bearing carrier spigot that protrudes out through the disk decreases in diameter at the end see http://www.s2forum.com/forum/showthr...oys+996&page=5
              Does the spacer have to fit snug over this reduced diameter section or does it not matter since the bolts will be holding it centre? I've never used spacers before so not up to speed with the do's and dont's.
              I'm thinking 205 55 16 might be a wee bit on the skinny size, am i right in saying that 225 50 16 has a similar rolling radius and if i use this size will they foul using the 10-15mm spacers up front and 20mm on the rear?
              Cheers Guys
                You need hubcentric spacers. 5x112 with a 57.1mm centre boss.
                  http://www.ebay.co.uk/itm/AUDI-A4-15...item4606c4d98a
                  I've used this company on ebay a few times and they've been helpful. I got my 80mm stud conversion from them, which is something to consider in place of longer bolts, as it makes fitting a lot easier. They do various M14x80mm kits.
                  • martinws
                    • Oct 2008
                    • 917
                    I run 314s on 3b alloys. 15mm spacers I think i Have. Been a few years since I fitted them.
                    • mackenzie50
                      • Mar 2010
                      • 740
                      I didn't run improved brakes on my 3B but I always used 15mm spacers bought from QST in West Sussex, made by MTM if tired memory serves me right. They do fill out the arches nicely+ make the early 5 spokes look good
                      • gmac78
                        • Oct 2009
                        • 928
                        • Home: Scotland
                        Yeh i must admit i'm looking forward to seeing what it looks like. I'm kind of worried they'll look dated but the alloys i've bought have a nice polished finish to them.
                        I think they'll look quite smart since the car sits fairly now on the H&R cups. I've never seen ones in the flesh but hoping they're to my taste.
                        Also, i'm hoping acceleration improves too as the current 18" RS4 reps weight something like 25kg with tyres!! Far too heavy.
                        • Cottis
                          • Feb 2011
                          • 1448
                          Comfortably the best looking wheels on an S2 in my opinion (if in good nick)
                          Chris had some some real high shine 3b alloys but I think he has them in his living room where he polishes them with a nappy. They look lovely.
