Anybody got a wise way of estimating best tyre pressures for non-standard configuration... other than trial and error of course !
I know the stock 205/55's run at 2.2bar on 7.5Jx16 but how do I estimate the best pressure for 225/40 on 8x18's - Is there a conventional way for doing this or what ?
I'd be interested to know this too, only my 225/40/18's are on a 100 S4! Tyre pressures when the alloys were delivered were 44psi but I reckon this is too high. According to the manual the tyres on the standard 16" wheels should be 34-36psi.
Paul
good question paul I and probably a few others would like to know the answer to this
sounds like they popped the bead and left them.whats the max.pressure on the tyre?
I run different pressures for different brands of tyre. I also did this when I had 205/55R16 tyres fitted. When doing this without equipment I try 36psi first then change to 42psi. See which one worked best of the two and then iterate towards a preference. Some tyres don't like high pressures, others must have it otherwise they are like driving on tyres made from jelly due to the sidewalls. I only set the car up for one person as when others are in the car or it is fully loaded it doesn't get caned too much. When loaded I check the car after about 30 miles of steady motorway driving to check the temps by hand before proceding.
If you drive your car hard you may have a particular preference to pressures to alter the way the tyres behave and react to your style. Just a few psi can turn a progressive tyre into one that no longer is.
If you don't drive too hard and want an inflate-and-forget I would run them at 36 for most brands. THere is no rule for this figure but it has served myself and the family well with tyre life for all sorts of driving.
Designun Limited....
