Will a little different in circumference between front and rear wheels be a problem?
  • EvenM
    • Nov 2010
    • 184
    • Home: Sweden Current: Norway
    Hello
    Will the little difference in circumference between front (1951.6mm) and rear (1976.7mm) effect the diff, or is it to little? The Reading at 60mph will be 60mph on front tires and 59.24mph on my rear tires. I have read that the torsen can accept some difference in circumferencs without problems.
    Btw, before you suggest same tires on front and rear wheels, I have tried same tires, but 205/40/18 would not hold air on 9,25 inch wide wheels No need to start a stance discussion, my choice to run wide rims
  • martinws
    • Oct 2008
    • 917
    What are you doing with nearly 2m high wheels?ha.
    I would always stick to same tyre sizes but I guess there must be a bit of slack as tyres can wear differently front to rear.
    • EvenM
      • Nov 2010
      • 184
      Ha? Circumference ; ) Think it will be okay with 215/40/18 on 9,25 inch rear wheels and 205/40/18 on 9 inch front wheels?
        I thought the tolerance on circumference was 4% but don't quote me.
        • A1QSHIP
          • Aug 2004
          • 975
          That sounds like some nasty stretching going on there.
          "Nulla tenaci invia est via"
          • cardcrash
            • Oct 2009
            • 763
            • Home: England Current: Wales
            Yeah, and I thought this was bad...
            RS2 - Project Mental Wheels
            RS2 - LHD on the road again
            RS2 - reduced to component parts
            RS2 Saloon replica
            A4 1.8T
            BMW 320d Touring M Sport Business Edition auto
            • EvenM
              • Nov 2010
              • 184
              Its not on the edge, I have been driving with 205s all around this summer. Only problem was one of the 205s on the 9,25 inch wheels started to loose some air, so consider 215 on the rear wheels instead. Or building the wheels to org. spec again, it would be better, but does not look as good
              I think it does not look like any golf with much camber and poke Click at the pictures
              From this summer
              With org spec
              • EvenM
                • Nov 2010
                • 184
                I have read all from 2-5 %, so dont know what to believe
                • PRY4SNO
                  • 767
                  4% is consistent with what I've read for Audi and Porsche.
                  2013 Touareg TDI /// #farmenwagen
                  • EvenM
                    • Nov 2010
                    • 184
                    Thanks
