Kumho, Falken, Nankang or Nexen?
  • Kumho, Falken, Nankang or Nexen?
    I need new tires for my 8x18 "Avus wheels.
    Since I do not drive so much with the car, there must be no very expensive tires.
    Previously, I always had the Falken FK 452.
    Now I want something else to test the lower price segment.
    In addition I have found the following tire.
    - Kumho Ecsta le Sport KU39
    - Nexen N Sera SU1
    - Nankang NS-20
    Has ever a one of these tires driven and can tell me to what?
    The tests in the car magazines I do not trust.
    I've used falken before I changed to Dunlop I rate falken more than the others and if you have used them before and trust them I'd stick to what you know as it works!??
      I have used Kumho Le sports, only problem was not much rim protection from memory but a very good tyre.
        The Kumho's are pretty good, but I would always spend as much as I could afford on tyres
          Indeed- and I'm speaking as someone who in the past ran (decent but not brilliant) budget tyres on my CQ7a, including Kumhos.
            Like Anthonys2 above I think Falkens are very good and if you like them, why change. I would doubt the wisdom of testing the cheaper end of the market, both from a safety point of view and I doubt if you tested a new one every week for a year you would try them all.
              That stunning car of your needs Goodyear asymmetric 2's which you might get a good deal on or the new Asymmetric 3's which have just hit the streets being rolled out in ever increasing sizes.
                Flakes fk453.. Price v performance they are top of the list and I'll be reshodding mine in yet another set
                1992 3b S2 Coupe
                  I used Falkens for a long time, good price and grip in wet/dry, a little too soft as they wear quickly. Kumhos are alright. GT Radials are a good tyre compromise in terms of price/wear/grip, used these alot on my 924/944 turbos. Michelin PS3 are a good tyre, cheap enough.
                    Khumo's are very good wheels!
                    Only a problem with they: in a hot clime on highway (on August), with a high speed driving you can see how the asphalt eat them.
                    PS: Falken FK452 are horribles, but those, the 452. Don't idea about the 453
                    photobucket SUCKS
                      I have now decided for Goodyear Eagle F1
                        Quite another price range and reputation, aren't they?
                          I have run both types, the cheaper directional and asym eagle f1.
                          the more costly asym is the best I used by far
                            I have come very low on a set Goodyear. Since the other tires were simply out of the race
                            According to many reviews, is supposed to be very good the Eagle F1.
                            • #15
                              I run vredsteinn sessanta's good tyre and a good price £63.45 per tyre from camskill
