Maximum Exposure
  • Chasman
    • 119
    Maximum Exposure
    Tom (audiman) has just finished fitting my new Big Reds - brand new parts courtesy of VAG Parts at far less than the jokers at Audi were asking, cheers guys! Tom's work is up to his usual diligent standards and he even took some before and after photos and gave them to me on CDs - try asking an Audi dealer to do that!
    They aren't even close to bedded in but pedal feel is immensely improved and and my hand brake is the best it's been since I bought the car.
    Next on the agenda - a second set of wheels. I want thinner spokes to expose the brakes more but keep the five spoke look. Just as an example I've attached some Forgeline examples of the syle I'm considering.
    1) I'm running H&R/Konis and the ride is pretty firm (and a little too low) - do I dare go 18"s or 19"s?
    2) Should I go up on width so I can go back to 245s?
    3) Will 245s fit if you run H&Rs? - looks tight to me...
    4) Can I get forged alloys like this in the RS2s peculiar size and offset (I don't want to use spacers)? Or should I just change the hubs to something with a more common stud pattern?
    Cheers,
    Chasman
    1994 RS2 in RS Blue Pearlescent
  • audiman
    • 4827
    Dont change the hubs as the discs wont fit!!!!
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Lee
      • 1512
      You need to machine standard Porsche wheels to fit the RS2 hubs and the offset is a few mm different. Not rocket science but not a straight bolt on either. I think you may have troubles with anything more than 225 on your setup. I have 235/40R18 on the rear and there is no room to lower the car to keep it drivable. It rubs occasionally on a cross country thrash (but never on trackdays) or when I have 5 people in the car it is just naff, and thats with stock springs!
      You can go 225/40R18 if you get the offsets right and that will mean some slight wheel modifications. You can go Euro look with stupid tyre sizes and slanty sidewalls but it is not going to be a very high performance car any more: just for show!
      Bodywork mods are then necessary if you want to go much wider and increase the diameter. Stock 245 RS2 tyre was much narrower than any other 245 tyre in production...the size on the original dunlop sidewalls was a bit misleading.
      If you go back to S2 hubs you will have to redo your brake setup!
      Designun Limited....
      • audiman
        • 4827
        I was very glad that the handbrake now holds on the slope leading to the bottom bays of our workshop, that is a good handbrake test. If it holds on there then it will defo hold on your driveway or when Sue takes it shopping
        Audi UR Quattro
