Aftermarket wheels
  • julesS2
    • Jun 2016
    • 68
    Aftermarket wheels
    Hi guys, first ever post and love the forum, have been offered a rare set of azevs but are 18x8.5 with an et of 42, have been told that these will need spigots to make fit, will these tuck nicely under a b4 s2 front and rear arch? please any help would be epic[emoji482]
  • diesel des
    • 3896
    Quite big and would need some spacers I would guess to stand a chance of fitting. I do like azev wheels.
    • julesS2
      • Jun 2016
      • 68
      Going to have a test fit in a couple of weeks time, am really hoping they fit!!! Shame they're not 8j wide hey!
      • diesel des
        • 3896
        Might need to use some slightly stretched tyres.
        • julesS2
          • Jun 2016
          • 68
          Yeah was thinking the same, not ideal but really love those wheels!
          • mackenzie50
            • Mar 2010
            • 740
            Can't see you failing to get them on your car - spacers (you might have to try different sizes) and maybe 225/40/18s -I've got that size on my 8.5 x18 BBS reps, they're slightly stretched but fine- I'm not a fan of the stretched look.
            Love Azevs....
            Welcome to the forum btw
            • julesS2
              • Jun 2016
              • 68
              Thank you for the reply, and kind welcome, had a go on that website, willtheyfit or something like that, how far do yours stick out from the arches? Shall try and avoid stretch as much as I can[emoji1360] will be posting more pictures up when I collect the car, it's an emerald green [emoji7]
              • julesS2
                • Jun 2016
                • 68
                • diesel des
                  • 3896
                  The track rod arms get close to the wheels on the S2 so hence the requirement to space out.
                  • julesS2
                    • Jun 2016
                    • 68
                    More than 30.4mm away from them hopefully [emoji1374] or I will most definitely have to use spacers
                    • diesel des
                      • 3896
                      For example this is a 17 x 7.5 et 35 wheel with 225 45 17 rubber. About 10 mm space on the inside so for rubber wider than 235 on 35 offset I would need spacers. On et 45 the issue would be 10 mm or rubber width 20mm worse.
                      • julesS2
                        • Jun 2016
                        • 68
                        Going to be mega tight isn't it, great photo that, thank you[emoji1360][emoji1360][emoji1360]
                        • mackenzie50
                          • Mar 2010
                          • 740
                          My 8.5s are a 35 ET I think , no markings on them, so just need very narrow shims up front to stop the tyres rubbing against suspension arms, as in the photo above, but my A8 Sport alloys are into the 50 ET territory so need 15 mm spacers...
                          • julesS2
                            • Jun 2016
                            • 68
                            Going to try a test fit once I get the car, without tyres and spacers and see where I am with them, just hope they fit, also been looking at Audi s3 8p alloys as a back up!
                            • BLAMM0
                              • Aug 2010
                              • 337
                              • Country: Lithuania
                              I had et30 8.5 width rims, and all was good. Add a 1cm spacer and you will be good to go.
