Will bbs rx 8/17 et 35 fit over 996 calipters?
  • EvenM
    • Nov 2010
    • 184
    • Home: Sweden Current: Norway
    Hello
    Searching for winter wheels and consider rx. Does any one know if they fit over 996 calipters?
    Thanks
  • Rusty
    • 18953
    Over 323 or less, yes.
    • EvenM
      • Nov 2010
      • 184
      Thanks, but Im also thinking about the distance from the calipters and out to the spokes.
      When I tried to put on the original 16 inch wheels, the spokes hit the calipter.
      Do you think 17 inch with et 35 will be alright ?
      Have no time / opportunity to try or measure before I buy
      • Ian_C
        • Oct 2007
        • 1011
        Do you have a bit of clearance to the arches to pop a few mm space in there if you have to? So at least if you buy them and they don't fit, you can space to the fronts until they fit
        B5 B6 B7 B9
        • Rusty
          • 18953
          I have 996 and 314mm and those exact wheels. They clear just fine.
          The 5 spoke alloys hit but the 6 spoke do not. A 10-15mm spacer will cure the problem if you want to run the o5 spoke 16s
          • EvenM
            • Nov 2010
            • 184
            Thanks for answers Bought a set rx for winter time
            • Rusty
              • 18953
              They have the added bonus of looking great, too
              • Ruffiano
                • Sep 2007
                • 1458
                Yes, and this is running the 323 rotors:
                17x8 RX 503II Et35
