wheel size question
  • Lee
    • 1512
    You are correct: ET45 + 10mm spacer = ET35 etc. Because the ET number is the distance from the centreline of the rim to the hub face.
    Lee
    Designun Limited....
    • Doug_RS2
      • 3847
      I have ET40 on the front with 235 tyres - these are about 4 or 5mm away from the steering arm.
      Assuming you have the standard steering arm(?), ET45 wheels, and 255 tyres in order for your tyres to be spaced away from the steering arm the same distance as mine you will need to "space" the wheel out 5mm, this would make your wheels an ET40. But you have tyres that are 20mm in width wider than mine so you would need another 10mm( half of the tyre width) to give you the 4 or 5mm gap I have - so you would end up with 15mm spacers, effectively giving you an ET30 wheel.
      Now I have written all this I remembered my tyre sits under the spring base - yours might need to sit to the outside of this( are they even standard?) because your overall diameter will be bigger - a lot bigger.
      My diameter is 19" + [ (235mm*35%) *2 ] = 647mm diameter
      Yours are 20" + [ (255mm*35%) *2 ] = 687mm diameter
      Have I confused you more? What is standard on your car? These are ideal sizes.
      I can take pics of mine if you want me to show you how close everything is.
      Another point is if your camber is well out, it might look worse than it is?
      Doug
      • Vagsport
        • 533
        Standard on my car was 205/60 x 15 ET 38, though I never had the car with the originals. I had it with 225 / 45 x 17 ET 35. I have not seen the 20's offered up to the car. Do you know where I can get good quality spacers of between 15 - 20mm? Sorry about all the questions.
        • Doug_RS2
          • 3847
          I meant are the struts standard? Are the steering arms that come off the struts standard?
          There are German spacers out there that meet their funny aftermarket regulations that are supposed to be good.
          • Doug_RS2
            • 3847
            #20
            Just thinking that your spacers are going to have to be specifically for Audi becasue you will need a spacer that extends the centre hub if you are going more than a few mm.
            Sportec wheels use spacers on RS4s for their wheels.
            • Vagsport
              • 533
              Struts and steering arms are all standard. Is there anything that is likely to foul at the back?
              • Doug_RS2
                • 3847
                #22
                Here's a good starting point:
                I think the suspension bases are really close on mine at the back.
                I cannot see 20" wheels with 255 tyres fitting in the front or rear arches if it has the standard suspension and standard arches. If you have standard arches/wings then you are going to have to modify the steering arm and spring bases so the complete wheel will sit further in. My 235 were rubbing on the front arches, that's why I took 5mm off the wheel but there is now only the 4 or 5mm gap to the steering arm.
                I'll take a few pictures tomorrow to show all the clearances I have.
                Time for some Ur box arches?
                  • 12431
                  that sounds right to me, i nearly fell into that trap with my wheels because had to get mine from an S6 which has a 35mm offset instead of the 45mm of the A4
                  • Doug_RS2
                    • 3847
                    #24
                    Demon Tweeks Link
                    Even Demon Tweeks do spacers.
                    • Dr H
                      • 1175
                      Or this place http://www.trackstore.co.uk/customspacers.html
                      There is a mistake on the site the A4 / 100 spacers should read 5 x 112 not 5 x 100.
                      • Vagsport
                        • 533
                        That is what my bodyshop is doing, the arches have been completely cut away, and he is creating a wide body effect in galvanised steel as on the Lancia Integrale. ABT and another German firm built S2's with similar arches, the ABT one was called the C5. My bodyshop has a copy of VW Audi Car mag and is using the pics for guidance. So really, the wheels can come out as far as possible. :eek2:
                        • audiman
                          • 4827
                          M8, with spacers that thick you will kill wheel bearings in days!! That doesn't seem right to me Maybe it is so that the wheels come right out to the edge of the arches or something?
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • Vagsport
                            • 533
                            When I get the car back, I intend to increase the track by having spacers made out of solid billet steel, but fitted between the strut and the hub carriers (where the two bolts attach the strut to hub carriers) that way the track is increases without compromising the integrity of the wheel bearings by moving the shoulders outwards. I also have spacers to fit between the inner CV's and drive flanges to compensate for the increase in track.
                            • Doug_RS2
                              • 3847
                              #29
                              Keep up with the topic young man they have to be spaced out past the spring bases because the overall diameter is that big - that is why the arches have to be made - to accomodate the large/wide tyres on the 20s.
                              • audiman
                                • 4827
                                Doh! Shouldn't type before i think. I knew what i meant, just cant explain it to you or me for that matter! ******** to it im gonna go to bed now.
                                Audi UR Quattro
