RS2 centre caps - what size are they?
  • Dr H
    • 1175
    Originally posted by loz
    Leigh
    I have RS2 caps in Mille Miglia Cup 1's - they have been machined down and are fixed in with a few blobs of mastic.
    If you go this route let me know as there is nother detail you should be aware of.
    I presume that you have machined the outside down to fit and then had to use the mastic because the RS2 has a smaller centre hole than the replicas? Do you caps have the audi 'rings' on them?
    Any advice would be very welcomed - send me a PM or share it with us all if you like
    Ex 1994 Avant - now driving a Lotus 340r
      If your using a bodyshop and paint then they should be able too match the Z17 Audi Silver (so a Audi Jedi Parts Master told me )
      • Dr H
        • 1175
        My car is Crystal Silver - not sure if I'd prefer my wheels a slightly different shade
        • loz
          • 47
          yes the central bore on the mille miglias is smaller than the porsche hench the mastic blobs on the lugs.
          yes they do have the four rings embossed on them.
          when machining the caps down the finished edge should be bevelled to allow the caps to sit flush - nice end result! - but no where near as nice as a sumptuous heated black leather interior!!
          • Dr H
            • 1175
            Loz
            Cheers for the info.
            Your subliminal adverts for your interior won't make my bank balance go up any faster!
            • BRY
              • 3755
              #21
              Dr H Let me know if they discount for quantity, as I'll chuck some S4 rims in with yours if you don't mind.
