Difference in Width.....
  • S2 Ant
    • 3682
    Im seriously tempted by some new wheels and im looking in to tyres etc
    From what ive read the S2 seems tighter on width than diameter on big wheels.
    Is there likely to be a noticeable difference between 225/40 and 235/35.
    I know diameter is about 15mm smaller on the 235/35 but as i said above its width that seems more critical.
    I also know that it depends on tyres etc etc, so if people are able to answer as best they can as im aware of the above.....
    235 / 35 / 19 = 647.1mm Diameter & 2032.92mm Circumference
    225 / 40 / 19 = 662.6mm Diameter & 2081.62mm Circumference
    & Incidently i currently have 225/45/17 which are
    225 / 45 / 17 = 634.3mm Diameter & 1992.71mm Circumference
    The 235/35 are a closer match but my understanding is width is more critical than diameter cos there seems to be more room up down than left to right (Hope that makes sense)
    and im waiting on a price for the 235/35, but have been quoted £880 all in for the 19's in 225/40.
    Ant
    2011 Kawasaki Z1000
    I'd search through for Doug's Post mate, IIRC you have to get hte offset spot on else they rub on the steering arms.
    I think Doug had to get his wheels milled.
      Check here http://www.s2forum.com/forum/showthread.php?t=325
      • dan_b
        • Sep 2003
        • 3670
        Bear in mind that 19" wheels make most brake discs look like 2p coins, even "big" ones!
        Also a 19" wheel is a lot of extra unsprung mass on each corner, which can actually make handling worse rather than better - obviously you're stiffening up the suspension by going for thinner side-walls, but you'll probably get more bump-steer, and I would imagine you'll get more understeer too.
        What style wheels are you going for? Are you lowered already?
        • S2 Ant
          • 3682
          Still standard ride height.
          Thanks Jamo yeh i remember Doug saying before he had 5mm machined off the front 2 wheels.
          Im gonna need some new tyres soon and for the difference in price its no real loss to do wheels as well.
          Its more about the look in town as i dnt rag my car often and if i do, its more on straight roads than round the lanes, the Audi is too big for that really for it to be real fun. I want another MK1 Golf for that kind of abuse.
          Ant
          2011 Kawasaki Z1000
          • imster
            • 143
            hey ant,
            just cos i recently learnt the hard way........
            Dont take ur last or current tyre dimensions as gospel, when buying new....i did this this and to my amazement found my new tyres rubbed on turning or going over bumps.....yet they were exactly the same size...different brand!!!!
            U might be ok if you are replacing like for like though.
            imster
            • Doug_RS2
              • 3847
              235/35 19s Toyo T1s ET35 will go on a lowered car. I got my front wheels machined as they rubbed on hard braking. But I still had a rubbing noise after and that was the mudflaps rubbing - maybe it was those that were rubbing all along!
              I will be getting a new set of 19s soon for my other car - so I can try them on the S2 and see if machining is needed.
              I had mine with 19s on track and it never rubbed - the visual differnece is massive - there are pros and cons handling wise - but the 35 rubber makes it very precise on small steering adjustments, especially on track. If you are commuting on bad roads, don't even bother with 35 profile.
              • S2 Ant
                • 3682
                Thanks Doug... all main road driving for me.
                Got tie rod ends and tracking to do and then i think i might take the plunge, im finding it hard to resist!
                Imster, yeh im aware of things like that, its more of a general consensus on the amount of room there is available and the amount of room there is for playing
                Ant
                2011 Kawasaki Z1000
                • Doug_RS2
                  • 3847
                  What wheels ant? I would love to see 19" RS6 wheels on it.
                  • S2 Ant
                    • 3682
                    Yeh it is the RS6 that ive been trying to resist for some time now.
                    My front tyres are excessively worn now where the tracking is out at the front and as im driving to Austria and back (approx 2000 miles) i wanna get it running straight and new tyres for the drive over and back so its all legal.
                    Ant
                    2011 Kawasaki Z1000
                      Don't think you'd have a problem selling the Porsche Cup Replica's mate!
                      You going for OE or Aftermarket RS6 alloys? quite alot in ebay at the mo.
                      • S2 Ant
                        • 3682
                        As above, ive been quoted £880 with the 225/40 tyres (Which is cheapest ive found them for by a fair bit) And im waiting for a reply on the 235/35.
                        Ant
                        2011 Kawasaki Z1000
                          Thats a good price considering this listing http://cgi.ebay.co.uk/ws/eBayISAPI.d...969211382&rd=1
                          • S2 Ant
                            • 3682
                            Yeh cos it was Rochford i was gonna go to as they are only about an hour drive away from me. But some guy starting up was advertising on a cruise site i use and quoted £880, but that was with the 225/40 tyres, i dunno if the 235/35 are more expensive or not.
                            Really want them on my car now ive decided to go for it, esp as its so sunny out today!!!
                            Ant
                            2011 Kawasaki Z1000
