Torque Steer
  • Sidspud
    • 1223
    Torque Steer
    OK - I know what it is, but what causes it and what can be done to prevent it?
    My S2 didn't have too much torque steer, but the 182 is terrible for it. There are times when I pull out to overtake, that the car doesn't want to move over to the other side of the road, and once there it won't pull in. Can be a bit scary if there's something coming!
    ex '93 Avant owner
    Ah the joys of front wheel drive cars!!!
    I'm afriad there's not really alot you can do with torque steer, is a common problem on FF cars approaching 200 bhp.
    I don't know if wider tyres help, was an old wives tale from my youth and i don't know how true it was.
    Read this article for an explanation of torque steer.
    • s2_southwest
      • Oct 2004
      • 823
      its to do with different lengths in the drive shafts isnt it? or at least that was the cause of the torque steer in my turbo mini, you could get equal length drive shaft kits to solve the prob
      Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
      • tamaquatt
        • Jul 2004
        • 43
        Wouldn't wider tyres increase the risk of tramlining??
          Thats correct !
          • Sidspud
            • 1223
            http://www.sportcompactcarweb.com/ed..._technobabble/
            That explains things quite well. Thanks for that.
            I like his final solution though....."keep both hands on the wheel"
            ex '93 Avant owner
            • mcandmar
              • Apr 2004
              • 5118
              Same goes for Honda crx's, anything over 1.6litre had equal lenght drive shafts and very little torque steer. How long did you have the quattro, might take a while to learn to drive a normal car again, i.e. get it straight then floor it.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • Sidspud
                • 1223
                Isn't tramlining and torque steer the same thing?
                ex '93 Avant owner
                • tamaquatt
                  • Jul 2004
                  • 43
                  I thought torque steer was generated by the amount of power / torque going to the front wheels and tramlining was a result of wide low profile tyres connecting with uneven road surfaces causing the car to choose it's own direction???
                  • s2_southwest
                    • Oct 2004
                    • 823
                    No, not the same thing.
                    Torque steer is when you have a certain ammount of power being driven to the wheels, through the drive shafts, the difference in lengths of the drive shafts will cause one of them to turn faster than the other one, resulting in the car being pulled to one side of the road, when power is applied.
                    Tramlining can occur at low speeds with hardly any power applied. difference in road camber and surfaces will cause tyres to follow those patters, the two fronts could be following different patterns, and when you have shot bushes, this effect is even more of a problem, as the bush is not holding the tyre/wheel in position.
                    That was my understanding
                    • tamaquatt
                      • Jul 2004
                      • 43
                      Worn top mounts cause the car to tramline too!! My motor has been WAY better since QR Sport top mounts were fitted.
                      • alg
                        • Apr 2004
                        • 1160
                        Abbott racing SAAB tuners used to fit a front LSD to cure this as the 900 old/new were producing 220bhp plus
                        Never got one for my classic shape 900t16s but they reduced it with uprated suspension and wider wheels (same size tyre which gave a superior tyre footprint).
                        Also did a wonderful line in custom ss exhausts
                        Alastair
                        RS2
                        • Henka
                          • 585
                          • Home: Sweden
                          "Become one with the understeer... You must overcome your inner fear of torque steer and become it's master"
                          Master Xin Ji, 1352 B.C
                          In another quote he added:
                          "FWD sucks compared to Quattro"
