URGENT-8.5Jx18 42E35 on an avant?
  • gavs20v
    • Sep 2004
    • 3057
    Anyone know if these will fit on an s2 avant?
    ive got 8x18's on at the moment with (what i think) is a 45mm et.
    Gav
    S2 Cabriolet.........
  • gavs20v
    • Sep 2004
    • 3057
    oh well ive bought them now so fingers crossed
    Gav
      • 12431
      you might need spacers for them but should be able to make them fit
      • Fat Audi 80
        • 10547
        Which tyre do you plan to use?
        The Perfectionist
        • gavs20v
          • Sep 2004
          • 3057
          good question, ideally 225/40x18 same as im using now. Theyve got this size tyre on at present so ill be able to try it first. My 8x18's are et 35 and theres only about 2mm gap between the tyre and rear trailing arm (although they dont foul) still trying to work out what the whether the et is 42 or 35 as theyre dual fitment .
          Gav
          • Mikes2
            • 1704
            They don't foul while the car is stationary on a flat surface. Might be a different story doing stupid speeds around a roundabout or a racetrack.
            Mike
            http://www.s2-audi.co.uk
            • gavs20v
              • Sep 2004
              • 3057
              With the 8x18's et35 ive got on now ive had them on track and they dont foul.
              Gav
                Is that ET35 on 8.5 J on an Avant? hmm thinking you'll have some trouble on the rear without spacers as the Avant is more cramped than the Coupe.
                Lee has posted quite a bit of detail on this, might be worth searching for his posts in wheel and tyres.
                • gavs20v
                  • Sep 2004
                  • 3057
                  Been searching, cant really find anything relevant, still looking though. Not sure if theyre et42 or 35.
                  Gav
                    ET42!!! whoa nelly
                    Hmm not searching hard enough my padawan
                    Originally posted by Lee
                    Hi
                    There is probably nothing in this post to help you but this is some additional info for Avant owners.
                    18x8.5 with ET32 would stick out on an avant. I fitted the largest (width wise) I could to mine although I could have gone to 19" at the expense of ride. I run 235/40 Goodyear Eagle GS-D3 (withdrawn from production now) and my rims have an ET of 35. Ideally it should be ET34 to clear the front steering arm and the upright at the rear. The rear upright loops over the top of the Avant's rear wheel to a small wishbone sitting just above the tyre. This is what makes it tight on the Avant. I run spacers to get them to fit and will be replacing my rear 3mm one for a 1mm spacer (bespoke) in a few weeks. I use 6mm at the front so that it doesn't look too silly due to the wide rear track. 3mm was the thinnest I could get at the time at short notice for the back. I would actually recomend not going above 225/40R18 if you have an avant. However I will be sticking to my current size as I know I can still get Bridgestone S0-2 tyres in that size. Amazing tyres they are and still available as a BMW OEM fitment!!
                    ET32 is a strange offset. Is that Mercedes wheel by any chance? You can fit them, as they have 5x120 PCD but the hub centre is about 66mm instead of the required 57.1mm. Custom hub boss adaptors are required to get these to fit properly. I looked into this because I really fancied a set of phatt Lorinser alloys. Couldn't find any secondhand so I went with my second choice (OZ Vela).
                    None of this is relevant to Coupe owners but additional info for avant owners.
                    Lee
                    BTW with the tyre size and brand I have fitted now, my speedo is accurate to within 1 mph from about 100 to just under 150mph.
                    • gavs20v
                      • Sep 2004
                      • 3057
                      cheers Jamo
                      and in the words of the almighty "oh crap!..." still not sure if theyre et42 or 35 yet. guess ill just have to suck it and see, dont really like the idea of using spacers or machining anything of the actual wheel but if needs must.....
                      Gav
                      • rotoryboy
                        • May 2004
                        • 3281
                        worth it though Gav, nice wheels matey
                        Mark
                        Race Clio RS197
                        S2 Coupe ABY (Green) - RIP
                        S2 Coupe ABY (Blue) - Sold
                        • gavs20v
                          • Sep 2004
                          • 3057
                          well theyre on and they fit, no rubbing. Outers need a refurb desperately as the laquers peeling, inners are spot on just need a clean. Plans for the future involve getting the outers polished, then maybe later get the centres powder coated anthracite grey.
                          heres some pics
                          Gav
                          • rotoryboy
                            • May 2004
                            • 3281
                            Tidy mate. Very tidy
                            Mark
                            Race Clio RS197
                            • Fat Audi 80
                              • 10547
                              They look nice! Well done.
                              The Perfectionist
