F1 Eagle reverlation
  • dan_b
    • Sep 2003
    • 3670
    @Andy - the important thing as far as the diff is concerned is for the overall rolling radius of each tyre to be more or less the same, so in those terms you can run a wider tyre on the front axle vs. the rear, or vica versa, so long as you get the right dimensions.
    If you put wider ones on the front you'll get more understeer but more potential braking performance. If you put wider ones on the back you'll possibly get less understeer/oversteer?
    • BRY
      • 3755
      Originally posted by audiman
      Some ppl cliam that it will damage the diffs, but to be honest i cant see how or why with such a small change. Some ppl even think that tyres should be changed as a set of 4 period. ****** that if i get a puncture and new a new boot!
      Some cars require a maximum difference in height on the tyre tread depth of 3~4mm IIRC.
      Vauxhall Calibra / Cavalier turbos to name and shame.
      My mate had one and had to have a recon centre diff @ £1000
      This is common on these cars, I've been told, by the guy who made a business doing the job
      Never heard of it on an audi though.
      • audiman
        • 4827
        Wider tyres upfront is to REDUCE understeer. MTM used to do that.
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
