Audi 7a 2.3 20v, No spark after driving.
  • alexandrusima
    • Jun 2017
    • 13
    • Country: Romania
    Hello, i own a Audi CQ 20v 7a, car doesn't have any spark, i checked the distributor, timing and ignition coil. I tried 2 diferent Distributor's and 3 ignition coils.
    The car is cranking but its not getting any kind of spark. Any other solutions ?
  • alexandrusima
    • Jun 2017
    • 13
    • Country: Romania
    There is no spark even from the ignition coil cable. Checked that cable too, doesn't fix it
    • Mikes2
      • 1704
      Check for fault codes. I've seen that when the flywheel pin is missing / broken
      Mike
      http://www.s2-audi.co.uk
      • Lago Blue
        • Jul 2009
        • 843
        Re: No spark after driving...
        Questions for Alex:
        Yes, as Mike has said above, codes might help. Any currently saved, note them, clear them and see which ones might return. Do you need help with that?
        Is this the first time you have noticed this "No spark after driving" has happened?
        You mentioned "after driving", does the engine start when cold?
        • Bowie69
          • Nov 2013
          • 2675
          Perhaps crank position sensor failure, two of them on the left side of the gearbox.
          Or the pin broken off the flywheel (been there recently with mine.....)
          • alexandrusima
            • Jun 2017
            • 13
            • Country: Romania
            Questions for Alex:
            Im going to have to get in contact with a friend, that has a computer , cable & software to pull out the codes.
            Let me recap how this happened, maybe it will help you guys out to give me a solution.
            I took a friend for a ride to show him the car, driving hard, shifting high and feeled how the car was like cutting out a bit, barely noticable. After that i parked it and from there the car cranks but has no spark, even when cold. I should have said this from the start.
            • steve briance
              • Aug 2014
              • 1455
              You don't need a computer and cable to read codes. All you need is a paper clip and a 12v LED! check out instructions on 20v.org or do a search on reading 7a flash codes.
              The diagnostic plugs under the dash are where you 'plug in' get the LED flashing, count flashes and compare against the tables out there on the Internet.
              • Lago Blue
                • Jul 2009
                • 843
                Alex,
                Bowie's idea about the flywheel senders makes sense with your symptoms (from what you said in that other thread, possibly both no fuel or spark), and it is quite easy to check these and replace them.
                You seem to have access to some spare parts, perhaps you have some extra senders, if needed , and an electrical multi-meter? You can meter them without removing them; or before installation.
                Also, IIRC, even though the two senders are colour-coded, they are otherwise identical, so can be substituted for one another.
                This old post may help.
                LInk: Good-bye to hot start issue on the CQ...
                • alexandrusima
                  • Jun 2017
                  • 13
                  • Country: Romania
                  Ordered some new Senders and going to check tomorrow, if thats not working, probably going to get the car on a platform and take it to a lift to remove the gearbox and check the so called pin on the flywheel. I doubt im going to be able too see the pin from the Sender holes
                  • Bowie69
                    • Nov 2013
                    • 2675
                    You can check the pin from the starter motor hole very easily, two bolts vs about 50!
                    • alexandrusima
                      • Jun 2017
                      • 13
                      • Country: Romania
                      Great, good to know.
                      • alexandrusima
                        • Jun 2017
                        • 13
                        • Country: Romania
                        Found the reason for no spark. Flywheel pin is missing.
                        • steve briance
                          • Aug 2014
                          • 1455
                          Excellent news! It's always nice to have a reason behind the problem.
                          It's a shame that solving the problem is quite a lot of work just to get to it.
                          • Bowie69
                            • Nov 2013
                            • 2675
                            Now check up at the back of the sump, through the slots in the bellhousing, check the two Allen bolts are still there.
                            That has been the cause for a few people on here, including mine.
                            • steve briance
                              • Aug 2014
                              • 1455
                              Ahhhaaa! I was wondering why the pin would just snap off in service. That suddenly makes sense when you mention those Allen bolts. If they dropped out I can see how that would take out the pin.
                              Every day is a school day!
