I recently purchased a 1991 Audi S2 3B Coupe. I have been reading for a few days on this forum as well as S2central. I have taken a few pictures of the problems I have found and wondering what part they are and if it is common. Both of my windows do not work. I took them apart and the cable in both of them has snapped the motors both work fine is there a cable and spool replacement kit? Also one of the window motors has broken off of its' mount. The blower motor doesn't even turn on is there a part number or a place I can order this? The main radiator has the top bleed screw like gooed shut to I guess stop a leak. Do you have a cost worth replacement site for the radiator and moutning and bleed screw? Here are the pictures of some leaks I found no Idea where they are ocming from. Also turbo boost is very iffy. Sometimes it engages, sometimes It does not. http://img13.imageshack.us/my.php?im...800x600xc9.jpg
http://img5.imageshack.us/my.php?ima...800x600mo6.jpg < there is oil leaking everywhere there as well as seen in this photo. http://img201.imageshack.us/my.php?i...800x600no7.jpg and this one http://img410.imageshack.us/my.php?image=img2225nu9.jpg
What is the part number for the drain nut? Also the oil filter?
Any help is highly appreciated.
Thank you!
Thank you!
