Unread 24-12-16, 07:56 AM   #271
maiks
Estonia
maiks's Avatar
Steering power cooling system was leaking... So finally I had time to repair it.. Checked with air compression and should be ok..
Then it was good time to put new TPS on place... The screw below was really ''nice'' to put back.. Especially when you have elephant fingers.. I managed to lose both screws... So I ordered new ones.. Then I lost one new one and while searching it, I found the old one...
Inlet temperature sensor also found its place.
maiks is offline   Post Tools
Unread 29-12-16, 06:31 AM   #272
maiks
Estonia
maiks's Avatar
Santa was late..
Unread 11-01-17, 06:34 PM   #273
maiks
Estonia
maiks's Avatar
I made pressure test to exhaust... So, like I thought, EM to turbo still leaks... This thing has been annoying me since I bought the stainless manifold.
So I took off the Em, turbo, wastegate and downpipe.
And changed the stainless flange to steel..
And again new ex wrap
Very stupid job to do.. Luckily I had one cold beer.. And an hour of free time..
Not an art work, but no radiator needed..
There is 15m wrap, 10m one piece
Unread 13-01-17, 03:29 PM   #274
maiks
Estonia
maiks's Avatar
Painted IC and pipes.. (Plastidip)
Oil cooler.
Before
After.
And a little more.. Home made engine mount.
Before
After
Unread 16-01-17, 04:33 PM   #275
maiks
Estonia
maiks's Avatar
Unread 16-01-17, 08:15 PM   #276
Kiku
Estonia
Kiku's Avatar
Good reading and best of luck on the build. What ecu are you running? Original motronic? Modded by Prj?
1990 2.2 20VT Audi Coupe Quattro
*Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmos
Kiku is offline   Post Tools
Unread 17-01-17, 02:28 PM   #277
maiks
Estonia
maiks's Avatar
Thanks. Yes, original mototronic and Dmitri mapped.
Unread 18-01-17, 05:13 PM   #278
maiks
Estonia
maiks's Avatar
And the other side...
I think I'll make something to avoid crap going to the bov. I really like its position because it is not seen under the bonnet. I like the clean look.
Unread 22-01-17, 02:47 PM   #279
maiks
Estonia
maiks's Avatar
Painted the exhaust manifold and downpipe wrap.
https://www.youtube.com/watch?v=0SbeKfbglG4
Unread 25-01-17, 05:30 PM   #280
maiks
Estonia
maiks's Avatar
If someone does not understand how I found out that my EM flange was bend.
Also replaced driver door hinge. On one good day, if I have time, I'll take it off and paint it also.
Replacing time was 15 min.
Here you can't see it, but the car nose is lifted up and with the old hinge the door didn't stay open, but with new hinge there is no problem.
To have access to one bolt, I needed to take off the wheel and remove some plastic.
Unread 26-01-17, 12:19 AM   #281
macspring
Fresh door hinges are cool the way the door stays open properly and doesn't 'drop' when opened.
Like a new driver's seat belt or a cleaned driver's seat belt - It retracts quickly and fully like a new car.
Enjoying the updates.
Unread 28-01-17, 09:14 AM   #282
maiks
Estonia
maiks's Avatar
Turbo has melted a hole..
New OEM
Changed
Unread 28-01-17, 02:35 PM   #283
Vorsprung durch Technik
Vorsprung durch Technik's Avatar
Really good to see a URS6 thread like this one with all the great work your doing!
Vorsprung durch Technik is offline   Post Tools
Unread 29-01-17, 11:29 AM   #284
maiks
Estonia
maiks's Avatar
Unread 30-01-17, 06:37 PM   #285
maiks
Estonia
maiks's Avatar
I made a heat shield also to avoid plastic melting..
Used copper plate because it is soft and very easy to work with (rubber hammer).
Between plastic and copper should be 1 cm room, so hope it works.
