Unread 19-10-07, 05:01 AM   #31
WOMBAT
United States
WOMBAT's Avatar
Billman - about how much did it cost to have the machining done, or did you do it yourself? I have a k26 kicking around and I bought a Holset WH1C from ebay over the summer and intend to combine the two. I guess I'm just looking for some helpful hints as well. Thanks! Looks great so far
WOMBAT is offline   Post Tools
Unread 19-10-07, 04:47 PM   #32
Billman
Billman's Avatar
Hi, a friend did it for a 6 pack Löwenbräu
I have measured tha Holset Turbine housing and machined the K26. Simple. The most critical part is the curvature that is also on the turbine impeller.
Go Holset or Go RS4
Unread 19-10-07, 09:02 PM   #33
WOMBAT
United States
WOMBAT's Avatar
exactly my concern - my knowledge of machining is sadly limited, but I have a class coming up which will help things. How was the curvature followed? Special milling tool head, or what?
Unread 05-01-08, 03:56 PM   #34
Billman
Billman's Avatar
No, the curvature was made with the guy that milled it experience (he measured the width of the curvature and done it). It is not how it should be done but it fits really nice with no probs.
Go Holset or Go RS4
Unread 19-02-08, 08:20 PM   #35
Billman
Billman's Avatar
VEMS PnP is on the way. Unfortunately no news on the engine itself.
I am also having the one Puppie (Holset) for sale and i will also upgrade the second one from 56/82mm 8 blade compressor impeller to 60/84mm 7 blade.
Go Holset or Go RS4
Unread 21-02-08, 02:53 PM   #36
Billman
Billman's Avatar
Here is also a map from the compressor i am going to use. It is the Super 40 map. I am going to try and find it in color.
The other HX40 map is from the 6 Blade 60/84 wheel.
Go Holset or Go RS4
Unread 21-02-08, 08:33 PM   #37
Billman
Billman's Avatar
and in color
Go Holset or Go RS4
Unread 27-02-08, 07:40 PM   #38
Billman
Billman's Avatar
New goodies on the way. I am going to convert the one HX40 56mm Comp inducer to 7 Blade 60mm (Super 40 specs)
Go Holset or Go RS4
Unread 27-02-08, 08:45 PM   #39
Billman
Billman's Avatar
There other HX40 i got is also up for sale. If interested PM.
Go Holset or Go RS4
Unread 01-03-08, 06:39 PM   #40
Billman
Billman's Avatar
New goodies arived:
Made some test with the connection ect. Will try to start it up tomorrow.
Go Holset or Go RS4
Unread 02-03-08, 10:49 PM   #41
Billman
Billman's Avatar
I started the Car today on VEMS. I havent installed the WB-Lambda and the EGT yet but idle was smooth somewhere at 850 RPM and with out load it revved till 6500 very smooth.
I heard that maybe the maybe the idle would not be so good ect before but it is actually very good. Without load and with this crap tuning for my car it was i dare to say at least as smooth as motronic.
I will comment on it further when i get there...
I hope tomorrow to install the WB and EGT so i can actually monitor everything.
Go Holset or Go RS4
Unread 02-03-08, 11:09 PM   #42
Billman
Billman's Avatar
Here is a small crap clip i made with the mobile. It is the very first start on VEMS.
http://www.youtube.com/watch?v=7nKIeTfZyaw
Go Holset or Go RS4
Unread 03-03-08, 05:02 AM   #43
A80Avant
Home Country - Greece Current Country - United Kingdom
A80Avant's Avatar
was it so easy???
what did you do?
A80Avant is offline   Post Tools
Unread 03-03-08, 06:00 AM   #44
Billman
Billman's Avatar
Yes it was relative easy. We will see how easy it was after it is properly mapped!
Go Holset or Go RS4
Unread 03-03-08, 05:35 PM   #45
Bram
Netherlands
Great! I am also following your personal VEMS page:
http://www.vems.hu/wiki/index.php?pa...Page%2FBillman
Bram is offline   Post Tools
