All greetings. I know that this subject has been raised many times, but would like to look to the end.
I apologize for my English.
Here is the data in a phased manner:
ADU:
@1mm ventilhub & ventilspiel 0mm
IN open OT:n after 13 Grad 034109021AN IN close UT:n after 35 Grad
IN max hub 8.3 mm. 202
EX open before UT 24 Grad 034109022G EX close OT AFTER 1 Grad
EX max hub 9.5mm. 205
toothed belt pulley 034109105B
AAN & 3B:
IN open TDC OT:n after 3 Grad 034109021AN IN close BDC UT:n after 25 Grad
EX open before BDC UT 42 Grad 034109022D EX close BEFORE TDC OT 9 Grad
EX max hub 8.6 mm. 213
7A:
IN open before TDC OT:n 6° 054109021 IN close BDC UT:n after 38°
IN max hub 9.6 mm. 224
EX open before BDC UT 42° 054109021 EX close before TDC OT 9°
EX max hub 10.5mm. 213
If we analyze these data, it is produced:
1) A intake turbocam (ADU and AAN) valve opens after TDC, but on the atmocamshaft (7A) valve opened up TDC. That is why torq e is lost. Since the exhaust gases enter into intake manifold.
2) Everyone knows that intake cam ADU and AAN the same. It is clear that the phase of the 7 A much wider intake cam, that is above its capacity. But there must shift its phase by 10 degrees. So do the same as has been done by professionals Porsche. You can shift the belt drive for a single tooth (7 degrees around). I think it works loss of torque.
3) Phase exhaust camshafts 7A and AAN the entire match can only favor at the expense of greater progress in the valve.
4) Citing a combination of different options camshafts:
a) intake AAN + exhaust 7А
IN open TDC OT:n after 3 Grad IN close BDC UT:n after 25 Grad
EX open before BDC UT 42° EX close before TDC OT 9°
b) intake 7A + exhaust 7А + phase shift 7 degrees
IN open TDC OT:n after 1 Grad IN close BDC UT:n after 45 Grad
EX open before BDC UT 35° EX close before TDC OT 2°
c) intake AAN + exhaust 7А + phase shift 7 degrees
IN open TDC OT:n after 10 Grad IN close BDC UT:n after 32 Grad
How do you think what option is best? What do you think about this?
Please forgive me if some mistaken.
ADU:
AAN & 3B:
7A:
